Old 07-05-2007, 10:58 PM   #26
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Just want to drive it again
go see if you can save that blazer
just use a covered aircleaner in the rain youll be alright
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-06-2007, 10:22 AM   #27
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I have to save in order to save that Blazer
I got an original aircleaner when i got the 69..... HMMMMMMMMMMM
LOW DOUGH is offline   Reply With Quote
Old 07-14-2007, 08:52 PM   #28
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I am going to try J B Weld the Radiator tomorrow. Hopefully
Old 07-18-2007, 02:44 PM   #29
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Old 07-18-2007, 02:48 PM   #30
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I put JB Weld on the radiator Sunday. No pics..... sorry. It had 2 pinhole leaks, one on each side. Next Sunday I will put it back in the truck and see if it works...... fingers crossed.
Old 07-18-2007, 03:11 PM   #31
2bits
2bits's Avatar
JB Weld will work, just besure it is totally dry on the inside and out so air can get to it. I did that with a gas tank once and it kept leaking until I finally bit the bullet and pulled the tank, drained it and did ti again. Solid as rock after that!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 07-18-2007, 03:23 PM   #32
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Thanks 2bits. Hopefully letting it set up for a week will do it. We'll see
Old 07-18-2007, 04:26 PM   #33
Jtrux
I'm a poor spectator
Jtrux's Avatar
You gotta stop and at least ask about the blazer, it looks alright from the pics. Just stop and ask for crying out loud, i'd drive up there for that!!!!!
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 07-18-2007, 05:11 PM   #34
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
My friend went and asked. It is the ladys kids truck and he wasn't home. I hate asking when I don't have any money.....
Old 07-19-2007, 08:30 AM   #35
OLDIRON69
Offer them $500 and I'll come pick it up...
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 07-19-2007, 12:49 PM   #36
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
if you pass on the blazer let me know i am looking
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 07-19-2007, 02:05 PM   #37
jasonb72
PorterBuilt Man Crush
Originally Posted by Reaper71 View Post
The 69 cab is in worse shape than the 71 and the driver side shock mount on the frame is gone. The hole and the metal that stick out so the shock bolts up at an angle is gone. I can’t believe I don’t have a pic of the shock mount. or whats not there
69 drum brakes
71 disc brakes
But.... I do need the radiator support brackets that are on the frame from the 69. The 69 clip and doors and probably the bed will also go on the 71.
Right now I just need to get it started so I can go ahead and put the clip on.
Does anyone now how you might get the brackets off the frame? How to remover the rivets? I am thinking an air chisel is the best bet??
Reaper,
Easisest way I have fouind is to use an air grinder and cut a star patern in the top of the rivet, then the air chisel will knock the top right out, then use the air chisel punch to knock it out. I had mine out in less than a minute.
J72
jasonb72 is offline   Reply With Quote
Old 07-19-2007, 02:33 PM   #38
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Thanks J72. I'll have to try that when I put a new core support in.
Old 07-24-2007, 10:00 PM   #39
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
It's been one year and four months........ I DROVE IT! Sunday I put the radiator back in and the JB Weld worked!!
This is before I took it down the road.
I got to clean the engine compartment up still.
Check out the custom door panels HAHA
Old 07-24-2007, 10:14 PM   #40
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
More
All the 71 front end parts and stuff
Still need to put the grill on and tighten up finders, bolt on cowl, and other stuff. The grill was not bolted on in all those pics. Took it back off the truck and went down the road. It sure doesn’t ride like an 06
Old 07-25-2007, 07:47 AM   #41
OLDIRON69
Glad to hear you got it goin!!
05 2500HD 6.0 excab
Old 07-25-2007, 11:28 AM   #42
Yukon Jack
Yukon Jack's Avatar
Congrats on your maiden voyage. Now drive over and get that Blazer
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-30-2007, 01:05 PM   #43
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Still not ready to drive it home. Didn't get to work on it this Sunday and probably not next Sunday either. D'oh!
Old 07-30-2007, 11:34 PM   #44
2bits
2bits's Avatar
Glad the radiator held! That's $150 you won't have to spend! Baby steps!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 08-08-2007, 04:09 PM   #45
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Thanks yall.... Sunday I plan on driving it home..... Hopefully the radiator holds in 100 deg. heat for 40 min. Someone will be fallowing me
Old 08-13-2007, 12:19 PM   #46
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I drove it home. It was running hot at 60mph so we slowed down to 50 55. We pulled over when it was getting hot and poped the hood. Guess what. IT STILL LEAKS OIL. That is why i took it out in the first place. This is the 4th time I have had it out trying to fix the oil leak. I just don't know what it is
Old 08-15-2007, 11:03 AM   #47
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Ok, I think it has to be the oil pan. The pan that is on it now came from a 350 that was in the truck when I bought it. That 35o blew up. I put a 305 I had in it with the pan from the 305. The old 350 pan stayed it the back of the truck with all my other junk. I drove it every day. When I put this 350 in about 3 or 4 years ago, I used the pan that had been in the back of the truck forever. I bet this pan is bent. When I get into my new house I will pull it again and put a brand new pan on. That should do it. I hope. Any ideas?
Old 04-15-2009, 12:23 PM   #48
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
digging it up from the grave. It is now in my driveway. Been there for a while. I will post some progress pics.
Oh, question..... I can't edit any of my previous posts on this thread. Is it because my name is changed and I started this thread with the old name? I was Reaper71.
I can probably edit this post though. Lets see.
Edit: YES I CAN
Old 04-15-2009, 12:27 PM   #49
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Oh, that oil leak was... The bolt in the front of the block was not there. I didn't think one needed to be there cause nothing bolts up there. So, I was wrong. That hole goes into the crank case. A short one goes there and you would put a long one in while changing the fuel pump. I have an electric pump. So, a 40 something cent bolt fixed the oil leak. No more buying cases of oil.
Old 04-28-2009, 01:37 PM   #50
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
lets see..........
I put some headers on it a month or two ago. Ran into a small problem. The colectors were jambed up against the 6 cyl crossmember that was still in the truck. Fixed that litle problem. Chisled all the rivets out and got the member out. Here are some pics. Enjoy....
Here is that crossmember that was in the way and didn't need to be there.
