Old 07-06-2007, 01:20 PM   #1
grayw0lf
How to deep clean a rusty radiator?
Does anyone know of a good method to clean out a rusty radiator? It doesn't leak at all, but you can see the rust clogging up the end of the cores.
I've been through 2 bottles of Prestone Heavy Duty Radiator Cleaner & flushed it several times. Its much better, but still not cooling properly at highway speeds.
I'm thinking muriatic acid or naval jelly in the radiator might be a step too far.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 07-06-2007, 01:31 PM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: How to deep clean a rusty radiator?
Take it to a radiator shop and let them boil it out. Thats about the best way to deep clean one.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 07-06-2007, 01:32 PM   #3
Richard H.
Spanked once
Richard H.'s Avatar
I like straight vinegar, cheaper and it does work !
Richard H. is offline   Reply With Quote
Old 07-06-2007, 01:32 PM   #4
topnos
topnos's Avatar
"Take it to a radiator shop and let them boil it out. Thats about the best way to deep clean one.
Jim"
Radiator shop is the best solution.
70 C-10
350/700R4, 2.5/4 drop
to be completed by 12/07
topnos is offline   Reply With Quote
Old 07-06-2007, 02:48 PM   #5
OLDIRON69
You talkin' about plain white vinegar? Do you run it thru the entire cooling system?
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 07-06-2007, 02:51 PM   #6
StingRay
StingRay's Avatar
And after it's all cleaned out there's a good chance it'll leak. Often the only only thing keeping them from leaking is all that crud. Lay it down, put the rad cap on and fill it with CLR through one of the hose nipples. It works like a damn for cleaning. Personally I've learned not to waste my time and I just take them to a buddy of mine that owns a rad shop. He usually ends up pulling both tanks and header plates and re-solders them all if the core is still serviceable. Half the time I end up needing a new core.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-06-2007, 03:43 PM   #7
Richard H.
Spanked once
Richard H.'s Avatar
Nothing will work as good as a radiator boil job or new one but yes straight white or cider vinegar. Same principle as your coffee maker and you can run it for a few days with no ill problems.
Old 07-06-2007, 03:59 PM   #8
OLDIRON69
The one I'm currently running is need of a little cleaning. In case it does start leaking, I have a good spare 4 core that needs to be in there anyway...
05 2500HD 6.0 excab
Old 07-06-2007, 04:51 PM   #9
luvmybowtiz
Usually running anykind of "flushing" fluid thru your radiator and cooling system causes larger chunks of crud to dislodge and plug up your core even more. take your time and money to the radiator shop and be done with it. Lots of time and money spent to learn this little advice.
luvmybowtiz is offline   Reply With Quote
Old 07-09-2007, 10:01 AM   #10
grayw0lf
Thanks for all the info. I going to pull the radiator this afternoon & take it to the radiator shop.
05' Dodge Neon
94' Seadoo SP
