Old 07-04-2007, 01:11 PM   #1
eedgell
It's the air up here
eedgell's Avatar
Question BBC guys: What exhaust do you have?
I have a 454 BBC. Nothing fancy just straight forward and stock. I use the factory manifolds as well. Just wondering what pipe size, and muffler combo you all find works the best? I want all the throat sound, but dont want to be a kid again, and it must breathe well.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 07-04-2007, 02:13 PM   #2
71/454
Turbo Guy
71/454's Avatar
Re: BBC guys: What exhaust do you have?
I have 2 1/2 with raptors, the holley flow tech brand. Sounds ok not real loud, not as throaty as I have on my 72(has flo pros witha 350). price was the deciding factor when I did the bigblock.
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 07-04-2007, 03:26 PM   #3
kwmech
2-1/2'' pipes off the cast iron manifolds into a flowmaster Y pipe then into a single 3'' muffler and pipe. That is more than what is needed for a stock big block. That is what i had put on my longhorn. My 68 GMC has a 396 in it. The previous owner had headers put on it with dual 2 1/2'' and the stock air cleaner with the 1 1/2'' intake for the snorkle--go figure. I'll be changing that when I convert to 4wd
Old 07-04-2007, 05:35 PM   #4
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
hooker comp full headers
18" of 3"
3" flowmaster knock offs
3' of 3" pipe.
the hookers are not a good idea if you have a lowerd truck,, they hang completely below the frame.
trkklr77 is offline   Reply With Quote
Old 07-04-2007, 06:39 PM   #5
SCOTI
SCOTI's Avatar
Sanderson 3/4 length Chevelle headers (1 7/8 primaries; 3" collector) w/3" pipe to Loback mufflers (24" case; 3" in/out) & all the way to the rear axle.
Nothing hangs below the frame rails & all bends are mandrel bends. Sorry.... no pics.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-04-2007, 06:39 PM   #6
71/454
Turbo Guy
71/454's Avatar
I have hedman shorty headers on mine. Original fit is for a 71 Monte Carlo I think
12 bolt diff
Old 07-04-2007, 07:14 PM   #7
72hotrod
72hotrod's Avatar
I like the idea kwmech has; elegant solution, no foo-foo. I am running a mild 427 with full-length Hedmans, H-pipe, 2 1/2 to the turbo mufflers, 2 1/4 tailpipes staight out the back. It was the same exhaust I had when I ran a mild 350. Not really ideal for either one for putting around on the street, but not too loud and not losing much if anything on the top, just some on the bottom. Like carburetors, I really think most people lose performance by going too big for how they really use their truck.
72hotrod is offline   Reply With Quote
Old 07-04-2007, 07:24 PM   #8
mnunn454
mnunn454's Avatar
I have a 454 with a Comp Magnum 550 lift/236@.050 duration cam, headers of unknown brand, and 2.5" pipes back to Flowmasters. From there I think it goes to 2.25" pipes and into 4" chambered extensions out the back. No X or H pipe. I love the way it sounds. The headers are not "shorties" and have either 1-5/8" or 1-3/4" primaries which I consider to be a little small for my application. I have both a 1 meg and a 5 meg movie of it either of which I'll email to you if you'd like to listen.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 07-05-2007, 01:25 AM   #9
albertarose
albertarose's Avatar
ceramic big tube long headers using stock manifold gaskets then dual 2.5 all the way out to the back ..I have stocktype Midas mufflers which are nice and quiet at normal rpms ..the kick is electric cutouts from badlanz just behind the headers .. they make this 396 sound like somthing you dont even want to be close to raspy nasty noise on demand ..LOL
albertarose is offline   Reply With Quote
Old 07-05-2007, 06:05 AM   #10
combustion
dual 3 inch with magnaflows
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 07-06-2007, 07:55 PM   #11
eedgell
eedgell's Avatar
Dual 3" sounds about right.
Eric
Old 07-06-2007, 08:41 PM   #12
Shaffer4
Strange Cousin From The West..
I'm running Dynomax Blackjacks designed for the Truck, they are 1 3/4" Primaries and 3" collectors, Running 2 1/2" Pipes all the way back, I had the muffler shop put on a Balance pipe, but I'm not sure if it helps since its back behind the Trans . I'm using Walker Mufflers.
Its pretty Mellow at Idle and around town (still has that nice rumble, but once you get into the throttle it opens up and sounds really wicked, not overly loud, just a really vicious note.
Of course that was with a fairly mild Comp Cams (in the .485 lift range). The New Cam is a .585lift Roller unit... so I am sure that will change the sound dynamic.
I'm almost certain that Dual 3" would be overkill and kill some Low-end (and daddy loves Torque).
Shaffer4 is offline   Reply With Quote
Old 07-06-2007, 11:08 PM   #13
eedgell
eedgell's Avatar
I dont think open exhaust hurts chevy v8's. They do like to breathe. The other brand x junk, seems to need back preasure, but not chevy. Even stock at the drag strip with headers, they run well.
Eric
Old 07-07-2007, 01:05 PM   #14
eedgell
eedgell's Avatar
I have turbo's and 2 1/2 in. with headers on my 1970 SS Nova. I like the sound. Kind of a rumble. It will vibrate the covers on most gas stations. 377 stroker BTW [stock bore].
Eric
Old 07-07-2007, 05:36 PM   #15
franks72
Junior Member
franks72's Avatar
My bb has a hyd roller comp cams 270h-R10 I used flowtec headers and they fit perfect , into 3 inch flowmasters . love the way it sounds . http://s94.photobucket.com/albums/l1...I_0948.flvunds.
franks72 is offline   Reply With Quote
