Old 12-14-2002, 03:12 AM   #1
herauf
herauf's Avatar
Question removing abs
i have a 96 s10 that has abs on it. i don't feel that they stop the truck as well as they should. the brakes work great until you have to slam on them hard. i have had abs before and know how it works, but my truck seems to lose too much braking power when they come on.
is there anyway to disconnect the abs and leave the truck with manual brakes? any help would be appreciated. i figured i would start here...
ryan.
1987 k5 4x4...FOR SALE!!! (email for details)
will eventually be replaced by a 70-72 4x4 k5
herauf is offline   Reply With Quote
Old 12-14-2002, 06:12 AM   #2
Alexis
Member since 2000
Alexis's Avatar
there should be a cable that runs to the hub. you should just be able to take it off. cause i thought ABS runs of a magnet then the computer understand the speed and when the tire start to lock up it release pressure in the brake line right or wrong?
Alexis is offline   Reply With Quote
Old 12-14-2002, 09:39 AM   #3
Capitol68
Capitol68's Avatar
I have heard of 4x4' ers removing the fuse while haveing fun
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
Old 12-16-2002, 12:10 AM   #4
Alexis
Member since 2000
Alexis's Avatar
our i rember the brake lines run through a little box which is where all the magic happens, take it out and reroute the lines.
Old 12-16-2002, 06:21 PM   #5
herauf
herauf's Avatar
i cant find a fuse for the abs and i don't see a box that the brake lines run through. i had looked at the lines before and i dont see anything that would be able to remove brake pressure....
i wish i had a 67-72 so i could actually work on it. computers suck...
ryan.
Old 12-16-2002, 06:26 PM   #6
Alexis
Member since 2000
Alexis's Avatar
the box can be protected, it will either run through tthe frame or in the engine bay. this little box is what allows the operation of ABS......you migh tnot have abs. did you look for the censors on your hub? it should be a wired that ran along the A-arm and spidle.
Old 12-16-2002, 08:08 PM   #7
love it loud
Calibration Engineer
love it loud's Avatar
i've worked too long and too hard for my abs.. don't wanna get rid of em any time soon!
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 12-17-2002, 12:05 AM   #8
Jesse 67 c-10
Jesse 67 c-10's Avatar
hehe, a thats what I though he ment!
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 12-17-2002, 01:40 AM   #9
cableguy0
all u hafta do is disconnect one of the wheel sensors and the abs will disable itself
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-21-2002, 08:09 PM   #10
pkbinplano
pkbinplano
pkbinplano's Avatar
Just push the emergency brake down one click. That should de activate it so I'm told. It will also turn headlights off on trucks equiped with always on headlights.
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 01-06-2003, 12:30 PM   #11
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs down
Ryan,
I dont reccomend disconnecting any safety related equipment if you ever get into an accident and someone die's and thay find you have intentionally deactivated the ABS system your screwed buddy. Just leave them hooked up your better off.
Have you installed aftermarket wheels & tires if so you may have confused the computer and it's not getting the proper signals from the wheel sensors anymore.
The computer can be recalibrated to compensate for this but you must go to the chevrolet dealer for that.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-07-2003, 03:30 AM   #12
herauf
herauf's Avatar
thanks. i had it checked out at the dealership in chico, and it brakes a little bit better now. funny they say they didn't do anything.....
ryan.
Old 01-07-2003, 10:50 PM   #13
BIGG BELLY
somrtimes the valve will stick inside the abs unit and not seat properly causing a soft pedal---putting the vehicle into an abs stop will seat the valve and make a hard pedal
55 big window long bed
69 olds 98
check out my pics
photo albums
BIGG BELLY is offline   Reply With Quote
