Old 07-08-2007, 04:04 PM   #1
1969k10stepside
Well,I could be driving the truck but...
The rear driveshaft isnt long enough The truck had a previous lift so I figured with the lift I went with (was not as tall as previous lift) that I wouldnt have to lengthen the rear driveshaft.Its not very much to short,but enough that it wont work.Im taking the overload spring out of the spring pack tomorrow lowering the truck about an inch,maybe that will lower it enough it will work.If not,then I guess I will have to have it lengthened...Front isnt long enough either,although I know its too short,its from a truck with a rockwell,not a np205.Do you think a rear driveshaft from a mid 70s short k10 will be long enough to work?Can get the whole truck for what it would cost to have the current rear driveshaft lengthened..
1969k10stepside is offline   Reply With Quote
Old 07-08-2007, 04:23 PM   #2
msgross
msgross's Avatar
Re: Well,I could be driving the truck but...
that sucks, did you reangle the rear axle?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-08-2007, 04:46 PM   #3
1969k10stepside
Nope...I went back out and managed to get it hooked up but it isnt pretty.You can see splines where the driveshaft extends...I am going to have one lengthened but this one will work for now...
Old 07-08-2007, 05:02 PM   #4
1969k10stepside
I almost shouldnt of even bothered putting the driveshaft on,there is still 3-4 inches of spline left in there you cant see though.
Now out to cut a hole in the floor and install the cab permanently!
Old 07-08-2007, 06:43 PM   #5
va_tlc
va_tlc's Avatar
dustin that stinks man.. but have you priced out a new custom built driveshaft? i didnt either, well until i had to go get some bolts from a machine shop that makes driveshafts also, well i asked and he figured up around 250 bucks and thats with new yokes and u joints also, i had a friend lenghten mine with a new u joint and that cost 160... wish i had just went on with a new one if only id known first... ohh and thats all new tubing too
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 07-08-2007, 07:05 PM   #6
I pay under $100 to have a shaft lengthened.
Old 07-08-2007, 07:11 PM   #7
va_tlc
va_tlc's Avatar
yea the first one i had done.. diffrent than the last lol was only 40 bucks, this time my u joint was like 30 bucks too, so still i had about 130 in just payin the labor this time.... darn inflation...
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 07-08-2007, 09:02 PM   #8
JAKES 68GMC
Aluminum slot wheels rule...
Driveshaft shops do nice work up here and have dirt cheap prices.
That sucks about the driveshaft Dustin.
JAKES 68GMC is offline   Reply With Quote
Old 07-08-2007, 09:21 PM   #9
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
If your splined stub & yoke are in good shape, I'd retube it. If they are shot, try to find one without wear out of a long box. It's the cheapest to shorten one since you are not buying tubing. If you do tube it, make sure the shop uses Spicer tubing. Neapco tubing is junk, their tubing isn't straight. Most of the better shops stay away from it.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 07-09-2007, 06:44 AM   #10
Jeff`s right.The shop I use will only use Spicer.That`s pretty much OEM.
Old 07-10-2007, 08:24 PM   #11
jamie72
jamie72's Avatar
i used a 72 3/4 ton shaft in the wifes and just shortend it(it has 3/4 axles)
it cost me $35.00
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 07-10-2007, 09:55 PM   #12
1969k10stepside
That sounds cheap enough.Is the place around where you are? I can install u joints so that isnt a issue,I just want to leave the lengthening or shortening of it to a professional.I'd like to have the current one lengthened.I just installed new u joints on it..
Old 07-11-2007, 11:28 AM   #13
JAKES 68GMC
I've got a LWB half ton driveshaft out in the shop I'd give you to shorten if you were closer/local Dustin.
