Old 07-10-2007, 01:14 PM   #1
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Angry Valve Sticking Open
So after driving my truck for the last two weeks, i noticed the other day that my right rear bag was filling to the PSI of the tank. after some thought, i realized that the fill valve was sticking open. I can get it to close if i hit the open switch a couple times, but it's a problem i'd like to fix.
Does anyone have any solutions that don't involve taking the valve out and replacing it?
I'm not running a water trap, and I do not have exhaust reducers or muffers on my dump valves. I plan to get something on the dump valves to prevent crud from getting into them soon.
IvelDesigns is offline   Reply With Quote
Old 07-10-2007, 03:24 PM   #2
kid66
kid66's Avatar
Re: Valve Sticking Open
I would take the valve apart and make sure there is no sand in it. I have had valves do that in the pass.
kid66 is offline   Reply With Quote
Old 07-10-2007, 09:30 PM   #3
ZBS 64
ZBS 64's Avatar
Take the valve apart and put some pnumatic oil on maine parts,also think about running some water separators.
ZBS 64 is offline   Reply With Quote
Old 07-10-2007, 09:38 PM   #4
Shane
Shane's Avatar
i highly doubt water is causing this problem ... these valves are designed for pneumatic systems and by the nature of compressed air they are going to have moisture in them.
Sounds like you have something lodged in the spool ... if you used Teflon tape on your fittings, then I would be almost willing to be that it's a piece of that.
Good luck and let us know what ya find out.
P.S. These valves are not complicated at all to disassemble ... pull her out and tear her apart ... the curiosity is KILLING me!
Shane is offline   Reply With Quote
Old 07-11-2007, 12:32 PM   #5
jimmydean
jimmydean's Avatar
Mine did the same thing. When my truck was parked, the right rear bag would slowly fill to equalize the tank pressure.
Take it apart and make sure it's clean. Might need to replace the valve.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-11-2007, 06:21 PM   #6
cajundragger
the valves are completely rebuildable, so as long as the case or the solinoid isnt broke then its fine. Clean it out really well, if that does work then buy the $3 rebuild kit and rebuilt it with a new diaphram and such.
cajundragger is offline   Reply With Quote
Old 07-12-2007, 09:56 AM   #7
IvelDesigns
Yeah, i think taking it apart is my only option. hopefully i can take the valve apart and clean it w/o removing it from the assembly i put together for each bag. I got lucky and had no leaks the first time, and don't want to create one now.
Here's a pic of the assembly i'm talkin about.
Old 07-12-2007, 03:11 PM   #8
randomhero472
randomhero472's Avatar
not to hijack.. but what gauge wire is recommended to run to the valves, my eai switch box has some tiny wires running into a connecting block (cat 5 size) and im curious if i can run similarly small wires.. thanks, hope you figure out whats up w/the valve
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 07-16-2007, 01:35 PM   #9
IvelDesigns
to the valves i'm pretty sure 16 gauge is suggested. the compressor needs larger wire though. 10 is what i used.
Old 07-16-2007, 01:54 PM   #10
itsmike2k
What valves are you running?
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 07-16-2007, 06:03 PM   #11
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Maybe Parkers?
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 07-16-2007, 06:49 PM   #12
Shane
Shane's Avatar
they look like SMC's to me ...
Old 07-17-2007, 02:20 PM   #13
IvelDesigns
Smc 3/8"
