Rocker box question
I have some floor and kick panel rust that I may try to repair. My rocker boxes are solid. Are they removeable to weld/repair underneath or do I just do all my repairs from above and??
this is on a 1972 Jimmy |
Cereal Killer
Re: Rocker box question
Wrongs forum....would be an ass load of work to remove plus you loose the structural rigidity they add. I would work around them and try to get a good look at them from the topside.
If I dont do it....somebody else will. |
Don't remove them unless you HAVE to. There will be an access panel that unbolts at the rear wheel wells. You can unbolt em and look inside... beware of spiders!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
You can do your patch work from above. I would not remove them unless completely rusted out as mentioned from Porterbuilt and onetonK5
its just $$$$$
I replaced the floor pans completely from the top side. it wasnt too horrible of an experience.
#7 | |
The rocker boxes contain torsion rods, both the boxes and the rods are welded in place. "Only" the rear panel unbolts. If/when floor repairs are done, reach inside and spray the repaired area from underneath to prevent future rust issues. |
![]() Join Date: May 2006
I hope yours unbolt, 35 years of rusted shut. I ended up twisting the cage nut clean off...then your left with more problems. Don't know what to tell ya, it's a gamble either way... JMHO
so far all the seat, seat belt, and top bolts all came out no problem. I am just trying to get as much information as possible so I can get everything I need and someday tackle my repairs. All you guys are great help. Wish one of you were closer so I could watch/help with someone elses before I tackle mine?
