Old 07-11-2007, 02:21 PM   #1
Simonstrucker
Big Block Short Bed Stepside
Cab Dipping
Anyone know were to get a cab dipped in Florida. How much it costs. Any info or suggestion would be great.
Simonstrucker is offline   Reply With Quote
Old 07-11-2007, 03:28 PM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: Cab Dipping
I would think twice befor dipping a cab. There are a lot of double wall areas on a cab and the inside unseen parts will be bare metal and I would think the humidity in Florida would rust it over night. JMO
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 07-11-2007, 03:48 PM   #3
killer71
killer71's Avatar
Re: Cab Dipping
Sounds like a good question for Hart Rod!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 07-11-2007, 03:53 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Cab Dipping
Plus, I've seen cabs fall apart from dipping it.
Old 07-11-2007, 04:01 PM   #5
Mt Man Chad
Mt Man Chad's Avatar
Re: Cab Dipping
I just returned from a shop that does them for $400 and and had one on the floor just dipped. Their is alot double wall areas that you can not get to for paint.
Now unless you know a paint dipping shop I would be a bit weary of doing it.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 07-11-2007, 04:51 PM   #6
StingRay
StingRay's Avatar
Re: Cab Dipping
What ever happened to Ed from Mothertruckers. He was in Florida and always dipped his cabs. His philosiphy was that there is no place you can't get to with a wand sprayer and some epoxy primer. http://www.mothertruckers.net/
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 07-11-2007, 05:06 PM   #7
Simonstrucker
Re: Cab Dipping
I wa asking because I just heard that they redipped the cab in a protective coating.
Old 07-11-2007, 05:11 PM   #8
72CSTC5
72CSTC5's Avatar
Re: Cab Dipping
Some places but few and far between will EDP dip the cabs. I personally know of none except the factories. Dipping is not a bad thing, these cabs came with no protection between metal anyways much like all of the old cars. You can use a wand system that most paint suppliers provide to recoat everything. It is just time consuming and would be beter off done on a rotisserie.
72CSTC5 is offline   Reply With Quote
Old 07-11-2007, 05:19 PM   #9
suville
suville's Avatar
Re: Cab Dipping
all gm products prior to mid to late 70 were bare inside captive panels thats why they rust out From the inside out more times than not. Sometime in the 70's they got a phosphate dip at the factory. Anyone that has worked in the autobody trades very long and especially professional restorers will concur with this, there is however a considerable amount of exterior rot from chemicals (salts) placed on icy roads.
suville is offline   Reply With Quote
Old 07-11-2007, 06:13 PM   #10
mbgmike
Re: Cab Dipping
Its getting harder and harder to find acid dipping companies for FED regulations. We have paid anywhere from $60.00 to $100.00 per piece. Like a fender, door, stake body gate etc. $300.00 for a 12' flatbed. Cabs ran $400 to $500.00 depending on how many other parts you gave them. Very little problems with rust in the confined areas. As said need to clean as good as possible. They neutralize the acid but occasionally it reappears from some of the seams. We used to get stuff dipped at International Harvestor in Springfield, Ohio during shut down. One time we had a mbg dipped. Thats when we learned you can't dip steel with aluminum skins. The guy dipping it didn't pay attention.
I know Atlanta, Ga still has some dipping places
Mike
mbgmike is offline   Reply With Quote
