Old 12-15-2002, 01:24 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Question Washing the washer bottle
I have a washer bottle that is all yukkey and yellowed...just like any 30 year old plastic part would be.
Does any one have a secret to making it white again that does not make it hard and brittle, and does not include spray paint?
I was thinking bleach at first, but that stuff can make things do funny stuff.
Old 12-15-2002, 02:44 PM   #2
Lippyp
English Chevy Owner
Lippyp's Avatar
Try normal clothes washing detergent (preferably the stuff for your whites!), nice strong hot solution, leave it soaking inside and outside overnight, a good scrub with a stiff brush, rinse and your plastic will be as clean as it's ever going to be. If the plastic has yellowed then there is pretty much nothing you can do about it as this is an irreversable change in the plastic caused by UV light. The bottle on my 67 came up nice and bright after a soak and scrub though. This also works well on other plastic parts such as light lenses to get the ingrained dirt out of the little dips and patterns.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 12-15-2002, 03:21 PM   #3
72MARIO
72MARIO's Avatar
What would happen if you put it in the dish washer ? Mabye that would work ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-15-2002, 05:16 PM   #4
BUXMAN66
go bucks!
ditto what lippy said.i did the same thing and let it set over nite.looked pretty good.steer clear of the concourse d'elegance events though!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 12-15-2002, 05:29 PM   #5
Gee_Emm
Geez man break down and buy a new one, what are they like $5.00 :P
They are still available from the dealer.
Gee_Emm is offline   Reply With Quote
Old 12-15-2002, 11:59 PM   #6
Longhorn Man
I know they are avalable...but if I'm gonna spend 5 bucks on it...I'll buy 5 plgs and wait for 3 mor dollars.
I kinda figured the yellow was there for good. I'll try the soak thing.
No dish washer...I had thought about that one already. Hmmmm, my sister has one though.....
Old 12-16-2002, 08:58 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Unfortunately, that yellow seems to be impregnated into the plastic forever.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-16-2002, 09:10 AM   #8
crazy longhorn
Fabricate till you "puke"
LMAO @ Longhorn! You do have a good idea tho.....its better to use Sis"s dishwasher &rile her .......she will probably forgive you,but you never know about the wifey (mine hates me for life)::p If the jug still holds coolant......it just a little slimy......its still good!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-16-2002, 10:04 AM   #9
Gee_Emm
I will put 25 cents towards the fund :P
Old 12-16-2002, 08:44 PM   #10
Iron-Butt
454 club
Iron-Butt's Avatar
tried soaking my but it is still yellow
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 12-17-2002, 04:34 AM   #11
Lippyp
English Chevy Owner
Lippyp's Avatar
You'll never get rid of the yellow, it is down to chemical changes within the plastic caused by age, UV light, pollution etc. It will; be throughout the depth of the plastic, the detergent trick just washes all the old ingrained crud off the surface.
Phil
'67 C10 long fleet.
