Old 07-13-2007, 07:09 PM   #1
chevybill
chevybill's Avatar
Question Installation question for the flaming river column FR-2007.
I am installing the flaming river column made for our trucks.
Do you grind the "nipple or notch" from the factory mount or do you cut a hole in the column for the notch to fit into similar to the facory column?
Thanks for your replies,
Progress is slowly moving with my chevy project, but that is life, I guess.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 07-13-2007, 07:33 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Installation question for the flaming river column FR-2007.
got photos?
Where is the notch at?
Old 07-13-2007, 07:42 PM   #3
chevybill
chevybill's Avatar
The notch or nipple is on the top side of the column where the column slides into the mount. I don't have any pictures, sorry. The stock column has a square hole cut in it for the nipple to fit into.
Old 07-14-2007, 10:35 AM   #4
chevybill
chevybill's Avatar
back to top for Saturday
Old 07-14-2007, 10:56 PM   #5
Bob Moore
Bill - does the FR column have a hole or a notch? I would think you would want to be as close to stock as possible. I would think the purpose is to keep the column from sliding forward or backward and from twisting left or right (say when at full turn when parking).
It does have a purpose and should be maintained - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 07-15-2007, 03:21 PM   #6
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
I don't have a flaming river column but i do have an ididit column and i had the same problem. What bob said makes sense but it is to late for me now as i grinded of the little peace sticking out.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 07-15-2007, 04:07 PM   #7
snj8198
snj8198's Avatar
I have a 30 inch FR tilt column and did not run into said such critter??
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 07-15-2007, 06:39 PM   #8
chevybill
chevybill's Avatar
I agree with your statements, but I do not think there is any way to accurately put a hole in this column with my limited tools.
Thanks for everyone's replies.
Old 07-16-2007, 12:24 AM   #9
Bob Moore
Bill - am I mistaken or would this take just a hole drilled in the jacket? Without measuring I would think a 5/16th or 3/8s hole would do the job.
vac, 454, T400
more to follow
Old 07-16-2007, 08:09 PM   #10
chevybill
chevybill's Avatar
How do you figure out where to locate the hole on the new column?
Once I drill that bad boy it is mine for keeps, you know what I mean?
Thanks for your assistance.
Old 07-17-2007, 01:00 AM   #11
Sandemonium
Proud owner of a 55.1 AD
Sandemonium's Avatar
I put in a FR-2003 column and was told to get the column set in place then tighten the mounting bracket and the nipple will make a dent in the column and prevent the column from moving back and fourth. So far I have noticed any problems, but the truck restoration is not finished yet.
Hope this Helps.....
Sandemonium is offline   Reply With Quote
