Old 07-19-2007, 07:53 PM   #1
Virginia72SWB4X4
Rear Shock Install?
I'm just about done installing the 4" lift. I still need to install the rear shocks.
Whats the trick to removing the top bolts? I've never seen shock mounts with the top bolt inside a cup like bracket.
Theres not much room between the frame and the bed, but I guess thats the expected way to get to the bolt head? I guess you have to custom bend a wrench?
Any experiences would be appreciated.
Gary
Virginia72SWB4X4 is offline   Reply With Quote
Old 07-19-2007, 07:56 PM   #2
1969k10stepside
Re: Rear Shock Install?
On mine,The nut comes off and the shock slides on the bolt.The bolt doesnt come off..
Dustin
1969k10stepside is offline   Reply With Quote
Old 07-19-2007, 08:12 PM   #3
Virginia72SWB4X4
Both bolts are loose on mine. It would make sense that the bolt its self would be fixed. That why I'm a little puzzled.
If push come to shove I'll cut them off and weld some bolts in.
Gary
Old 07-19-2007, 10:18 PM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Hey Gary, are you going to bring the truck to cruise night when you get it done?
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-20-2007, 08:10 AM   #5
Virginia72SWB4X4
Chuck,
Yep, I'll bring it up. It's not much to look at. Front bumper is bent, rockers and door bottoms have issues.
It's like having an ugly baby, you see the potential....
Hows the custom camper coming?
Old 07-20-2007, 10:20 AM   #6
Yukon Jack
Yukon Jack's Avatar
Mine was loose on the drivers side and I couldn't get a wrench in there. I took the existing shock and pushed it into a bind so it was holding the bolt tight. Then I was able to get the nut off. Did the same thing when I put on the new shock and once I started to tighten the nut it the bolt grabbed and I was able to tighten it properly.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-20-2007, 10:45 AM   #7
CUSTOM/10
CUSTOM/10's Avatar
The rear shock mounting studs are supposed to be welded in. The head on them is round so you couldn't get a wrench on them if you wanted to. I've had to replace these in the past. It's easiest if you have the bed off the truck. If there in good shape just reweld them, if not replace them with a bolt and weld them.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 07-20-2007, 11:36 AM   #8
Virginia72SWB4X4
Thanks guys, that makes sense they are intended to be solid. I'll get them in a bind to remove the shock then tack them with a welder.
When I pull the bed I'll probably put in a cleaner bolt and weld permamntly
Gary
Old 07-20-2007, 12:22 PM   #9
72 CustomCamper
huh ???
Originally Posted by Virginia72SWB4X4 View Post
Chuck,
It's on hold for now. I blew the trans up with the big block,so I sold the 396 to buy a mustang...
Chuck
