Old 07-20-2007, 05:11 PM   #1
wyatt earp
oops, greattt!
the po of the '72 can't find the keys for it, so i went and got a new ignition lock cylinder. only to find that you can't take the old one out unless you have the keys. so does anyone have any ideas or know how to do this with out tearing up the ignition switch and chrome bezel(which i couldn't get to come off either) it feels like it will un screw to a point but won't come seperate from the switch part. if i can't get it out without tearing it up then i'll just wire everything in with indivdual toggels and call it even.
wyatt earp is offline   Reply With Quote
Old 07-20-2007, 05:23 PM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: oops, greattt!
There are MANY archive posts about this.
Easiest way is to unplug the wirring harness from it and take a saw zaw and cut the old one out (in half) from the back. It will come apart and you can slap the new one in.
10 min job.
72freak is offline   Reply With Quote
Old 07-20-2007, 06:54 PM   #3
Truck Hippy
Truck Hippy's Avatar
Re: oops, greattt!
I have used a drill and a large bit to get the switch out before. Its not a big deal to get it out, just takes alittle work.
Truck Hippy is offline   Reply With Quote
Old 07-20-2007, 09:07 PM   #4
Bob Moore
Re: oops, greattt!
Do a search for LocDoc. He is your best bet to doing this with a lot of damage.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 07-20-2007, 09:34 PM   #5
'68 longbed
'68 longbed's Avatar
Re: oops, greattt!
doesn't the key actually just push a button in the back of the cylinder? i was thinkking you could use a paper clip or somthing.
the 50"s chevy's could be pulled with a paper clip.....used to piss a buddy of mine off, great fun!!
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. "
'68 longbed is offline   Reply With Quote
Old 07-20-2007, 11:01 PM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: oops, greattt!
You need the key, after you use the paper clip to push in the little pin, you have to turn the key counter clockwise past off...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-20-2007, 11:11 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: oops, greattt!
Check out this thread from yesterday.....
http://67-72chevytrucks.com/vboard/s...d.php?t=250254
Or this one from a couple of days ago.....
http://67-72chevytrucks.com/vboard/s...d.php?t=250193
LockDoc
Leon
