07-22-2007, 09:24 PM | #1 |
shaved firewall....and heat?
probably a stupid question ....
i see alot of ya'll shaving the firewall. is just a regional thing and you don't need heat? ...or air for that matter? is there an trick to having a clean firewall and having heat? I'm thinking some old t'birds had electric heaters has anyone tried to make somthing like that work?
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. " |
07-22-2007, 09:44 PM | #2 |
Re: shaved firewall....and heat?
now they'll most likely have heat/ a/c, the bulky box on the firewall is replaced by a better, smaller, under dash unit...
07-22-2007, 09:50 PM | #3 |
fan motor aswell? looking at mine it seems that you could shoehorn fan and some sort of ventilation box in there. is there a late model "somthing or other that the parts that work? or is a fabrication job?
07-23-2007, 01:52 AM | #4 |
There are several aftermarket A/C companies out there that make units specifically designed for our trucks. I too shaved my firewall and will be going with either an OLD AIR unit or a VINTAGE AIR unit (Both OLD AIR and VINTAGE AIR are manufacturers of aftermarket units). I love the shaved look and hate the way the factory heater and especially the A/C looks, like luggage attached to the firewall.
Hope that helps... Mike |
