Old 07-23-2007, 11:53 PM   #1
eric67m
eric67m's Avatar
Timing chain?
I have a 67 K10, SBC, 4spd, NP205. My timing chain had around 12 degrees of slop so I decided to replace it. I pulled the plugs and put the turned the engine over to TDC and felt for pressure coming out of the #1 cylinder. I then exposed the timing chain and found that the timing marks do not line up. I removed the valve cover to watch the valves on #1 cylinder and felt again for pressure. My engine is on TDC but the cam dowel pin is 180 off from every installation manual that I have ever seen.
I assume I could install the new timing chain with both dots up. Is this common for a 283 or 327?
Also I cannot find the suffex code for the engine on the website that I have checked
Block: casting # 3828180 suffex T0325HCH
Heads: 3890462 c236 Camel humps built march 23 1966.
Any info on either of these would be greatly appreciated.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 07-24-2007, 12:01 AM   #2
cdowns
cdowns's Avatar
Re: Timing chain?
the 2dots are supposed to point at each other in the middle//the cam at the 6oclock position the crank at the 12oclock position// installing the timing chain has nothing to do with tdc compression stroke
Old 07-24-2007, 12:18 AM   #3
Green Machine
Green Machine's Avatar
Re: Timing chain?
We had a thread about this a while back. Your engine is just fine, when both dots are at 12:00 it is compression time for number 1 cyl. When the crank is at 12:00 and the cam is at 6:00, like you would normally line it up, it is compression stroke for number 6 cyl. Turn the crank around one more full turn tom make liking up easier and don't mess with your distributor and you wll be just fine.
I think the HCH, the last H means Holley carb equipped. I'm doing this from memory, but the HCH could be a holley equiped 327, Kind of rare I think, I have one of those blocks here with HCH, a 327 block, small journal, might be worth some bucks to a restorer.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-24-2007, 12:42 AM   #4
eric67m
eric67m's Avatar
Re: Timing chain?
Thanks for the replies. So turn one more turn so dots line up and distributor is at #6. This is what I was kind of thinking but just wanted to make sure.
Green machine---- what Holley carb would have come on this engine? What style, BBL#s and CFM? The "CH" codes I found for suffex translations = 1958 or 1962 283ci.
Old 07-24-2007, 07:28 PM   #5
mnunn454
mnunn454's Avatar
Re: Timing chain?
Exactly a 2:1 ratio between crank and cam by design.
Ergo, the cam alignment dot can be in either the 12:00 or the 6:00 position (as long as the crank is in the 12:00 position) and it'll work file. However, it's easier to ensure the cam's in exactly the right place (not a tooth off) if you'll orient the cam mark in the 6:00 position.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 07-24-2007, 07:45 PM   #6
Green Machine
Re: Timing chain?
http://www.chevy-camaro.com/chevy-ca...es.asp?group=4
This link has the HCH code, 1966 327 with power glide and Holley carb, that is the block I have, I'll try to see what the rest decodes to and post back.
Old 07-24-2007, 08:59 PM   #7
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Timing chain?
Turn it so the dots will align with each other and you will be golden (don’t worry what the dizzy points to)
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 07-24-2007, 11:55 PM   #8
Green Machine
Re: Timing chain?
I bet the block casting is 3858180 instead of 3828180 as I could not find the 382 anyway the 3858180 number acording to mortec is :
3858180....327...64-67...2
And given the date codes on the heads are 1966 pretty sure you have a 327
and the camaro site had the HCH code, 1966 327 with power glide and Holley carb, the T0325 means Tonawanda plant March 23.
I really think the HCH might be a big deal maybe to some Vette owners.
