i love summertime
gears instead of timing chains
anyone know where i can hear those gears online? thinking about ordering one , just curious to what they sound like... also im thinking about a quiet one...thanks
Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
Almost Satisfied
![]() Join Date: Mar 2002
If you are building a daily driver it will drive you nuts! They are loud. I think they sound very cool, but I want to hear the cam not the gears. Just my .02 I'll do a quick search for a web site....
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
i love summertime
thanks, yeah it is going to be a daily driver but im young and i like loud, also i dont have a wild cam in my truck so iwanna be able to hear something..heh loud is cool, scares all those little honda boys
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I had a "quiet" one in my Model A. It drove me crazy, but I must admit that the blower is just as bad.
Young Gun wth Fast Inline
Gear driven cam
I have a gear driven set in my truck. It is an inline6 however. It is a cloyes angled cut and you can hear it, but it is not very noisy. Between the cam lope from the exhasut and that sound it would be totally quiet.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Fabricate till you "puke"
For $45-50, you can pick up a decent true roller chain setup.....& have more bucks to spend elsewhere on your project
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
go bucks!
it literally 'bout drove me crazy when i had my '69.yeah,it sounds killer but for a daily.........uh,uh!my $.02
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
I love the pete jackson gear drives
![]() I have one in my supercharged camaro and let me tell you......The blower and the gear drive are singing together! ![]() Summit and jegs high performance both sell them. Get the extra noisy if you want a "supercharger wine"
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
I need another Barley Pop
Randy, how loud was the "Quiet" version? I bought a new PJ "quiet" for my big block but haven't put it in yet. Is it going to be louder than my 50 series Flowmasters? You guys are making me have second thoughts!
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
Suburbans RULE!
I have a Pete Jackson "Noisy" gear drive in my 388. When I drove the Burb daily it didn't bother me at all. I think they sound cool as hell.
My exhaust is way louder than the gears, with 40 series Flowmasters and 3" pipe I would hope so. ![]() I would recommend a gear drive over a timing chain, I hate changing out chains that stretch. ![]() ![]()
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
I thought ALEX posted a sound clip video of his gear driven engine in his 4x4. It was in General discussion a couple weeks ago
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
i love summertime
thanks dubie, ill have to look for it
I have heard rumors that they could send vibrations though the engine and do damage, but how could this be when gears run so much smoother. I think there just saying that because they dont have one. Rock on Noisy Pete.
97 ext cab 4x4 04 pontiac grand am 05 honda rancher AT (yellow) 71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter |
#15 |
![]() Join Date: Nov 2002
I like the gears, but what about a belt drive? Jesel or others?
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
#16 |
I had a Milodon single idler gear on a 68 Camaro I had. It lasted about a week. You could hardly hear the motor running once the exhuast was done, just the yowl of the gear drive. I was 17 at the time and hated it which should tell you how obnoxious it was... As far as a belt, it is a low-mileage replacement part. They are quiet which is one of the goals of new cars and why most imports use belts. Our Bimmer motor was redesigned in the E36 with a chain instead of a belt which is fine by me, I hate chaning them. Just buy a good chain and be done with it. Save your money for something that will add real performance and not just noise. Depending on the motor, gear drives can transmit crankshaft harmonics to the cam and valvetrain and cause failures in rare instances.
#17 | |
#18 |
Used to have a truck
The only time you really NEED a gear drive setup is when you are running super hi tension valve springs. They'll stretch a chain in short order. You wouldnt use springs like that on the street. Theyd wear your cam lobes to nothing and the cam that needs them wouldnt idle under 3500 rpm so why would you use a noisy gear drive? I dont know of anyone who hears a gear drive and says "That guy must have some motor" . What I hear is ... " What a dumbass! He could have spent the money he spent on that gear drive on a months rent at the trailer park ".
No, I don't like them.
No truck :-( Last edited by mikep; 12-17-2002 at 09:59 PM. |
#19 |
i love summertime
hmm i dont know what to do, i think it would be cool, and different at the same time, but yet i dont want something that will toast my cam or any other parts
#20 |
Do it....if you dont you will always wonder...its a 100.00...when your tired of it..sell it on ebay...Sometimes you have to learn the hardway..Im like that
![]() Jim
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
#21 |
The belt drives are not built for the street. Most are an open face setup for ease of adjusting which is fine for the track.. but for the street you'll have that belt torn to streads in no time. Timing belts designed for OHC engines are long enough and thick enough to withstand the pressures of daily driving.
I've got a set of "LOUD" gears in the 355 and I love 'em! The lope of the cam combined with the gears makes me want to find stop lights just to hear the symphony ![]() Last edited by Piston; 12-17-2002 at 10:46 PM. |
#22 |
i have the edelbrock setup and love it. no more chain stretch and the noise isnt bad at all. at around 2000 rpm i cant hear em anymore but of course that is probably due to the 40 series flows but who cares i like it
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#23 |
They sound like a p/s pump going bad to me. . . .
#24 | |
![]() Quote:
GEE WHIZ -- I HAVEN'T LIVED IN A TRAILER SINCE I WAS 18 (SOME 26 OR 27 YEARS AGO) BUT THEN AGAIN I DON'T CLAIM TO BE A PIMP EITHER, SO OUR TASTES PROBABLY DIFFER ![]() ![]() ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 12-18-2002 at 12:47 AM. |
#25 |
i love summertime
mike, i have never heard one and was just curious more than anything else, im only 19- a.k.a i like things loud-and like to turn heads, and if it is too loud, big deal, ill get a chain and swap, afternoon of wrenching....to each is own eh
