Old 07-25-2007, 10:26 AM   #1
UP GRADE
one set closer
UP GRADE's Avatar
changing from 67 to 72 spindle
when doing this do i need the lower and upper ball joints and tie end rods for the 72 spindle.
UP GRADE is offline   Reply With Quote
Old 07-25-2007, 08:18 PM   #2
trukindud
trukindud's Avatar
Cool Re: changing from 67 to 72 spindle
as long as you have a haf ton to haf ton youll be sweet if you try and change from 3/4 to haf i dont know the answer yet well hope that helps
trukindud is offline   Reply With Quote
Old 07-27-2007, 05:21 PM   #3
69swbman
u need to get the upper and lower ball joints replace if nessceary but u need to replace seals and bearings if needed also regrease and repak bearings this dosent take long iv already done it ALSO REPLACE brake lines if their rotted
69swbman is offline   Reply With Quote
Old 07-28-2007, 09:36 AM   #4
dave2953
Dave's not here, man
dave2953's Avatar
If you used the inner/outer tie rod ends you'll also need the centerlink. You can use the outer tie rod ends, but you need a sleeve adapter to make them work with the 67 inners.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 07-30-2007, 03:05 PM   #5
UP GRADE
one set closer
UP GRADE's Avatar
dave2953 If you used the inner/outer tie rod ends you'll also need the centerlink. You can use the outer tie rod ends, but you need a sleeve adapter to make them work with the 67 inners.
where can i get a sleeve adapter.
