Old 07-25-2007, 06:36 PM   #1
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Grounding the rear bumper
I'm trying to get some rear bumper license plate lights to work. I have 12 volt power but cant seem to get a good enough ground. If I use a test light it works using the bumper for the ground and the probe in the 12 source. But the license plate light wont come on. All the other lights seem to be fine. I've checked fuses they checked out okay. Thought about using a jumper cable to link the negative side of the battery to the frame and see if that helps any.
Im using a motor mite / doorman 68151 unit.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-25-2007, 07:59 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Grounding the rear bumper
are the unit in good shape no corosion also are the bumbs in good shape. my groung goes to the lights ground from the tail lights.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-25-2007, 08:33 PM   #3
1LoC10
Insert Title Here
1LoC10's Avatar
i put one of those U shaped terminal ends... dont know what they are called, and srewed it into the stock light holder on the bumper to ground mine
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-26-2007, 10:25 AM   #4
MylilBowTie
Right turn Clyde
I sanded the area where the lights go into the bumper. Sanded some more on an few other grounds to get better contact. Unhooked the rigged up trailer wire harness all seems good now.
