Old 07-28-2007, 05:42 PM   #1
skokie
skokie's Avatar
How to prime a power steering system
I have changed out my worn out power steering gear for a new variable rate redhead. The question is how do I prime it? Do i just fill up the power steering pump and start turning the wheel or is there more to it than that?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-28-2007, 06:06 PM   #2
Zeke
Active Member
Re: How to prime a power steering system
I have always poured steering fluid into the lines to get as much as I can into the gearbox then connected them to the pump, filled pump and with the wheels off the ground and engine running slowly turned the wheel stop to stop, check fluid level fill and continue untill I don't have to add anymore. This makes sure all the air is out of the system. Air in the system is worse for the pump that the gearbox.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 07-28-2007, 06:21 PM   #3
krue
Designated A-hole!
krue's Avatar
I just fill the pump and turn stop to stop with it on the ground.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-28-2007, 09:41 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
when we were doing the frito lay rebuilds at work, the P/30 trucks always got a new steering gear box and pump, and seperage resivour. We tried a few ways, but this is what worked best.
Fill the system up as soon as it was sealed up. With the engine off, and the front end up and secure on jack stands, turn the wheels from lock to lock a few times, then refill the system. Do this 2 or 3 times, untill the level stays pretty much full.
With the front end still up in the air, fire the engine, let it idle for amin or two, then turn lock to lock slowly, pausing for just a second against the lock. Center the wheel, shut the engine off, and come back in 10 min to check the fluid. if drasticly low, top off and fire it again and turn back and forth.
once it looks good and isn't groaning, set it down and go around the block, check it one last time, top it off and call it good.
Old 07-29-2007, 04:25 AM   #5
68K20 x Drill
Good advice
Longhorn man, maybe you can answer a Frito Lay question for me...
my friend has one, a 79 with 4BT engine. It has a PS pump for the Hydroboost brakes but a manual steering box. What is up with that
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 07-29-2007, 11:26 AM   #6
Longhorn Man
Hmmm, never heard of a truck with the hydro boost but without power steering.
You could add power steering easy enough.
In all reality, that truck was probably a gas powered truck originally, and had power brakes, but not steering.
Once converted, there was no vacume to run the brakes, so they installed the power steering pump to run the hydro-boost system.
Old 07-29-2007, 05:46 PM   #7
skokie
skokie's Avatar
Ok I gave this a shot and now I have power steering fluid oozing out of the cap. I started to open it and it reminded me of a radiator on hot day so I said uuuhhh I dont want to wear power steering fluid so I stopped. Did I now let the truck run long enough? I let it run for 1-3 minutes. Do I need to go longer? Also it is groaning when I turn the wheel.
68 build thread
Old 07-29-2007, 06:04 PM   #8
skokie
skokie's Avatar
I started it back up and it stopped spitting up fluid. I let it run for 2-3 mins and shut it down. I did not turn the wheel or anything. I opened the top and I see a ton of bubbles. What next
68 build thread
Old 07-29-2007, 07:02 PM   #9
skokie
skokie's Avatar
Ok it seems to be doing better. Just taking a while. Its now groaning just a little bit. I shut down the motor and checked it and it was way low. I topped it off and I am now letting it set for 10 mins.
68 build thread
Old 07-29-2007, 07:34 PM   #10
Thealien
Thealien's Avatar
raise the front wheels off the ground. With the engine off slowly turn the wheels lock to lock about ten time. Check fluid fill as needed. Repeat until it doesn't take any more fluid. start it up and turn lock to lock a couple of times, shut off and check fluid for level and bubbles. If fluid has bubbles/foam repeat the earlier steps.
Good luck
Last edited by Thealien; 07-29-2007 at 07:35 PM. Reason: Too stupid to spell correctly
Old 07-29-2007, 09:03 PM   #11
skokie
skokie's Avatar
Yep did all that and all is well now. No more noises and turns on a dime..
68 build thread
Old 03-26-2008, 10:27 PM   #12
bguild
bguild's Avatar
I know this thread is old but thought I would ask this here. I have a leak in the power steering pump.. Its coming from the bolt where the line goes into the power steering component. Not the Pump on the block but the other part. Its the line closest to the radiator It seems to be leaking from the bolt where it threads in.. I want to do the cheapest fix and i did try to tighten it.. It moved a little but I think it might still be leaking.. Is there like thread tape I can put on these lines and then refill the pump? Its extremely low anyway from having the leak.. The great thing is I just got this truck and the fluid has leaked all over the control arms so it should be fun cleaning that all up.. Its nasty..
bguild is offline   Reply With Quote
Old 03-29-2008, 03:49 AM   #13
72gmcworker
72gmcworker's Avatar
Just replaced the box and pump today on my '72 2500 and without reading this first I followed Andy's method.....seal it up, add fluid, with engine off turn wheel lock to lock, add more fluid, do lock to lock, when it takes no more fluid start it up and all is good.
Works like a charm
72gmcworker is offline   Reply With Quote
Old 03-29-2008, 03:54 AM   #14
72gmcworker
While I'm here
Try teflon tape or pipe dope on threads....if it is the pressure line....mine threads onto a fitting that threads into the pump...do both ends of the fitting if yours is same.
Old 03-29-2008, 04:48 AM   #15
truckdude239
truckdude239's Avatar
never use teflont ape on a hose that has a flare fitting it will just make it leak
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-29-2008, 06:11 AM   #16
bguild
bguild's Avatar
so with that in mind if mine is leaking and the factory is a flare fitting (unsure cause I havent taken mine out) Then what do you recommend??? Do I use pipe dope or just replace the lines with new? The lines look good but the seals just leak.. I can try to crank it down more but I dont want to strip anything out.. I dont have alot of experience with this stuff and I know alot of you guys here on the board do so anything would help.. Thanks in advance.
Old 03-29-2008, 06:23 AM   #17
Longhorn Man
Works like a charm
Sweet. Like I said, we tried a few ways, and that worked best.
Old 03-29-2008, 05:05 PM   #18
72gmcworker
My 2 cents
You got nothing to lose...
you got a leak you want it stopped
So
take it apart and check condition of pieces...flare, nut, (check and pull the threaded insert into pump) steel line parts (is nut turning free on steel line) plus rubber hose, return line hose for hardness/rot and connection/clamp.
replace if condition iffy....saves a blown hose or so on the road.
if okay dope it and crank it all tight...if still leaks replace it all and be done...then your good for another 30-40 years
I had some leaks and now it is all new...pump hoses and box.....done for another 30+/- years
Teflon tape or such should not come into play on a flare connection as the flare is the seal ...not the threads
but if you got nothing to lose...heck you never know...dope it.
'70 Pontiac Firebird Esprit
'72 GMC 2500
'90 GMC V1500
'94 Dodge Cummins 2500
'02 Dodge 2500 Quad Cab Long Box 4x4 gasser
Old 03-29-2008, 05:10 PM   #19
bguild
bguild's Avatar
My 2 cents
So
Thanks for the advice.. when i get from Chicago next week I will start ripping into it.... I hope it goes the cheap way cause I have alot of other stuff I want to buy for this truck. (-;
