False Lies
suspension problem
hello, im having a doozie of a problem with my front suspension/steering. the slower i drive, the more my truck pulls to the right, and the harder i brake, the more it pulls to the left. im kinda confused. all new ball joints. my power steering pump has been giving me a hard time.. i dont see how thatd be the problem tho. and when i look underneath, everything seems fine. any help??
Kyle (Steemin) Ehman -1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO" -2015 Yukon XL Denali (Family ride) -1977 Chevy stepside, carb'ed vortec 350 (SOLD) -Father of three daughters who will also have something cool... |
Hellasick
![]() Join Date: Jul 2006
Re: suspension problem
pulling right while driving---alignment off or stuck caliper
pulling left while braking---stuck caliper I would have to start with the right caliper...hangs up while driving and doesn't clamp as hard when braking. after driving get near the right front wheel and see if you smell a hot brake. I had this prob with a car of mine. when hit the brakes, would pull left, but would also "reset" the right caliper which would drag until the pads wore(sp?) down.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
False Lies
alright that sounds like the problem.. and i can definately smell burnt brake on the right side. so how do i fix this problem??
Hellasick
I would start by replacing the caliper. Then the hose to the caliper.
how old are the hoses on it (brake ones that is)? Might be worth replacing them if they are real old while the system is opened up.
hoses first
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
#6 | |
If not, the caliper piston will compress the pads to the rotor & then stick vs. pulling back. They sell grease made for the pins or you can use hi-temp bearing grease. Clean the pins w/some thinner or brake cleaner & a mild scotchbrite. Are the bearings greased properly? In good condition? Tightened properly? This stuff is free vs. buying new hoses & calipers that may not be needed.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 07-31-2007 at 02:03 PM. |
