Old 07-30-2007, 11:12 PM   #1
beermunk
Throttle cable / gas pedal "stiffness"
I was wondering if this is just my ignorance of having an old vehicle or if there is something I can fix here.
The issue is that the gas pedal seems stiff when initially pressing it. After it's down for a little bit it has the same resistance as I am used to in driving a new vehicle. It's really noticeable when I'm in 2nd gear and initially hit the gas. I get a jerk in the throttle.
The only way to remedy not jerking the tranny like this is ride the clutch a little bit but I don't want to continue to do this. I've already given the throttle spring some wd-40 and sprayed some on the accelerator pedal.
Any thoughts or is this just the way these old trucks run?
1969 Chevy LWB / 2WD / 307
"You better take care of me Lord, or you'll have me on your hands..."
- H.S.T
beermunk is offline   Reply With Quote
Old 07-30-2007, 11:16 PM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Throttle cable / gas pedal "stiffness"
these old carburated trucks are going to have a stiffer pedal than a new car, personally i like having the stiffer pedal and when i drive a new car it feels like theres nothing there
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 07-30-2007, 11:19 PM   #3
herb101
Used Register
herb101's Avatar
May be due on the throttle return spring being too tight. You may be able to find another location to secure it or it may not be the correct spring - too short of a spring will cause a stiff pedal.
Herb
herb101 is offline   Reply With Quote
Old 07-30-2007, 11:34 PM   #4
skokie
skokie's Avatar
I ran into this myself and I agree with Greasmonkey72 I like the pedal stiffer. On mine it was due to a spring the width of 3/8s wrench and about 4-5 inches long.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-30-2007, 11:36 PM   #5
68gmsee
Active Member
68gmsee's Avatar
After you check all of the mentioned parts, I would disconnect the link to the carburetor and see if you still have a hesitation.
If you don't, suspect the butterfly shaft (name?) in the carburetor. I had one do that once and the carburetor shop fixed it. I think they replaced the shaft. Been a long time ago.
You may also want to spray carb cleaner on the throttle body as you open and close the throttle in case you have some gummed up fuel in the carb throat.
68gmsee is offline   Reply With Quote
Old 07-31-2007, 12:24 AM   #6
beermunk
I will say that the spring coming off the throttle body looks like it's from a mattress. I'll see if I can find something OEM to replace it with.
- H.S.T
Old 07-31-2007, 12:25 AM   #7
beermunk
i'll check that too. thank you so much for the response!
- H.S.T
Old 07-31-2007, 01:02 AM   #8
skokie
skokie's Avatar
That was a stock spring. I thought it wasnt so I asked a guy who rebuilds carbs. Said that they were that big on most 68s.
68 build thread
Old 07-31-2007, 05:04 AM   #9
cdowns
cdowns's Avatar
sometimes 40year old parts work easier if they are cleaned and lubricated. star at the foot pedal and go to the carb
Old 07-31-2007, 05:56 PM   #10
beermunk
True enough. Thanks!
- H.S.T
Old 07-31-2007, 06:03 PM   #11
71tahoe
71tahoe's Avatar
My son's 69 had the same problem. It was the pedal surface that slides on the throttle arm. We used some lithium grease and it helped but didn't completely eliminate it. Check where they contact and like cdowns said, move to the carb.
71tahoe is offline   Reply With Quote
Old 07-31-2007, 11:13 PM   #12
Jim_PA
My gas pedal was simply worn out where the rod contacted the plastic pedal, and the ball studs/sockets that connected the pedal to the floor were shot too. I replaced the gas pedal for less than 10 bucks, and it's smooth as silk now
Mine used to stick right when I'd go to hit the pedal... once I got it off an idle, it was fine. I actually drove with no pedal for a while because it was driving me crazy.
Jim_PA is offline   Reply With Quote
Old 07-31-2007, 11:30 PM   #13
72 68 andmore
some day you will yearn for stiffness LOL sorry I had too
72 68 andmore is offline   Reply With Quote
