Old 08-02-2007, 01:58 PM   #26
blk81shrt
blk81shrt's Avatar
Re: Lowered Pictures - Inspiration Needed!
Hey 79chevylover which leafs did you remove? I Wanna Know aswell
blk81shrt is offline   Reply With Quote
Old 08-02-2007, 02:17 PM   #27
moneyeater
moneyeater's Avatar
I have 2,5" dropped spindles with 1,5" drop coils in front and a flipkit out back.
I removed 2 leaves wich didnīt affect on the drop but should ride smoother!
Tires are 265/50/15 in front and 295/50/15 on 15x10" Eagle alloys!
Name:  rechte Seite.jpg
Name:  Red C 10 Lwb.jpg
moneyeater is offline   Reply With Quote
Old 08-02-2007, 03:57 PM   #28
boatpuller
boatpuller's Avatar
here's one....4,6 is what belltech said.it came out lower.(thats a good thing.)it's c notched and flipped in the rear.and 3 inch drop spindles,with 1 inch coils.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 08-02-2007, 05:57 PM   #29
79chevylover
I don't recall how many I had to begin with but I pulled out the big thick one on the bottom and I think the next one above that. I remember the leaf pack being really thick and it rode like a 1 ton. Just have 3 left now. I think if you pull the thick one on the bottom and the next one it should give you a couple of inch drop. I don't tow anything or haul anything heavy otherwise it might be a problem since you are taking away tongue weight capacity and also cargo weight capacity. It seems to ride like a half ton should now. Hope this helps. Trial and error is how I approached it. I had more time than money. It gets tiresome going back and forth so hopefully that will give you the desired drop. I also used 2 inch drop shackles and had to notch the bed supports for this so if you plan to use the drop shackles you might want to notch those bed supports while you are at it and everything is more out of the way. I didn't do that while I had things out of the way and it made getting my grinder up in there a little more difficult and not as "pretty".
79chevylover is offline   Reply With Quote
Old 08-02-2007, 08:48 PM   #30
Slonaker
Insert Witty Text Here
Slonaker's Avatar
That's a really nice truck, 79chevylover. You are sort of local, too.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-02-2007, 11:37 PM   #31
dubdeuce80
dubdeuce80's Avatar
i don't remember the details, but it was low...5/8, maybe 6/8ish?
dubdeuce80 is offline   Reply With Quote
Old 08-03-2007, 12:45 AM   #32
longhorn71
longhorn71's Avatar
2"Spindles 2" shackles with all 5 rear leaves
8 x 10 american racing wheels
245/60 15s front 275/60 15s rear
I am pretty sure the blazers had the same rear springs as the pickups
longhorn71 is offline   Reply With Quote
Old 08-03-2007, 07:36 PM   #33
gotit
gotit's Avatar
big peice of crap
[SIZE="6
Code:
HTML Code:
[PHP][/PHP]
"][/SIZE]
gotit is offline   Reply With Quote
Old 08-05-2007, 01:45 AM   #34
blk81shrt
blk81shrt's Avatar
Hey boatpuller wat size id rms and tires?
Old 08-05-2007, 02:35 PM   #35
boatpuller
boatpuller's Avatar
seventeen's...............225/55/ in front..........275/55 in back.
Old 08-05-2007, 04:17 PM   #36
KMK454
KMK454's Avatar
Here's a photoshop of my truck:
Kurt
Instagram: @kurtkphoto
1978 C10 Silverado
1991 Camaro B4C
KMK454 is offline   Reply With Quote
Old 08-08-2007, 02:49 PM   #37
blk81shrt
blk81shrt's Avatar
nice rim combo boatpuller i love the fat rears.
Old 08-08-2007, 02:56 PM   #38
blk81shrt
blk81shrt's Avatar
KMK454 wat drop is ur photoshopped pic supposed to be? nice work on that by the way.
Old 08-08-2007, 05:46 PM   #39
lownfast
Gettinlow & Goinfast
Originally Posted by 79chevylover View Post
Mine has 3 " drop springs in front and 2 " lowering shackles in the rear with only 3 leafs left in the rear. It rides nice. 295/50/15 on 15 X 10's all around. I had 2 1/2 " drop spindles in the front before but they would not work with my wheels
what beautiful ride. post up more pics of your truck!
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline   Reply With Quote
