PorterBuilt Man Crush
![]() Join Date: Jul 2007
What size bags
I am going to get the Slam Specialties bags, but should I go with the RE7's or 8's. I am not goingt o be laying frame.
Thanks |
![]() Join Date: Aug 2005
Re: What size bags
RE7's all around seem to be the bag of choice for these trucks. That's what I have too (based on research on this board).
Re: What size bags
RE7's
Re: What size bags
Thanks, PM'd you again
GM ONLY BABY!!!
Re: What size bags
I decided to go with the RE7. An S10 would use an RE6.
Please post any items for sale in the parts board.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up Last edited by centsless; 08-04-2007 at 08:46 PM. Reason: for sale by non subscriber |
Re: What size bags
on my 84 im useing re7's in the front and re8's in the back with a canti-lever setup.
Re: What size bags
Most guys run RE7s up front and RE8s in the rear on s10.
Jake 68 c10 project 99 s10 laid on 20s 98 blazer slammed on 20s |
Outlandish Trends - FL
Re: What size bags
umm, I'm definitely going to have to disagree with you on this one.
-Bret 67 short-fleet sold! |
Re: What size bags
The RE8 would be alright in the front if you were running a big block and needed the additional lifting capacity. It's going to be close to rubbing on some of the suspension if you were using 1/2 ton suspension items.
The reason guys will run an RE8 on the back is for lift, and ride. The larger bellow bag will ride softer due to the internal capacity of the bag itself. Plus the bags will lift the truck higher at a lower pressure so you can get the height and ride that you were looking for.
#12 | |
Re: What size bags
www.s10forum.com about 90% of the guys running slam bags have re8s in the rear. ![]()
Re: What size bags
#14 | |
Re: What size bags
#15 |
Re: What size bags
You can get an RE8 up front in an S10 like the picture shows, but look atg the amount of material removed from the frame. You can get the same amount of drop and like with an RE7 in the front of an S10, the RE8 will just ride at the same height with less pressure.
The front spring pocket of the 63-87 C10 trucks are totally different. You can get an RE8 in there but the problem will be with clearance issues on the lower bumpstop mount and swaybar mount. The RE7 will be perfect up front and still give an easy 9 inches of travel. All the trucks that I've built always had the RE7's up front with the exception of one dually with a 454. I went RE8's on there to compensate for the additional weight of the motor and the fact that it was crewcab longbed truck.
