Old 08-03-2007, 12:33 AM   #1
Deuce
Deuce's Avatar
Idea for a theft deturent system
classicchev and I were discussing different ways of starting a 67-72 w/o having to turn the key all the way to the start position,
What we came up with for my trucks bezel with the provision for a choke is to mount a windshield washer switch in the "choke" hole.
So the process for starting the truck would be:
1) turn the key to the "on" position
2) push the windshield washer switch "In" (the one in the choke hole in the bezel) as if you were to operate the washer pump. And have this wired to the starter to "start" the truck
So you would still have a key for security and a "pushbutton" starter.
Any thoughts?? Maybe we're not as smart as we think we are??
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 08-03-2007, 12:47 AM   #2
wibilly
wibilly's Avatar
Re: Idea for a theft deturent system
it won't work. it's not a secret anymore!!!!
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-03-2007, 12:48 AM   #3
68 short step
mental note: when steeling deuce's truck push wiper button in...
sound wonderful, except why would the theif have the keys to begin with?
68 short step is offline   Reply With Quote
Old 08-03-2007, 01:46 AM   #4
Ackattack
Ackattack's Avatar
I may just wire a switch underneath the dash that disables something (lots of things to disable that won't let it start) and then I'd be the only one that would know about it.
If you use a washer pump as a switch, might want to think about using a relay in line with it to handle the amperage.
Ackattack is offline   Reply With Quote
Old 08-03-2007, 06:13 AM   #5
70GMCer
70GMCer's Avatar
Man....you just took the wind out of his sails.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 08-03-2007, 09:06 AM   #6
OLDIRON69
On another car I have I use a Moroso "dead man" switch. It kills all power to the car. I have it mounted under the seat. It's a simple set up. On the other hand, now a days, if they want it bad enough they'll come back with a wrecker.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 08-03-2007, 09:32 AM   #7
Orange
Licensed to Thrill!
Orange's Avatar
If a thief wants it bad enough, he will get it. Period.
BUT - he did say theft deterrent - so - no Deuce, this isn't a BAD idea.
Takes more than a turn of the key to start the truck, so no simple switch breaking technique will work.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 08-03-2007, 10:35 AM   #8
my70chevyc10
my70chevyc10's Avatar
I had a 1964 ChevyII station wagon that i hooked the heater switch up to the electric fuel pump. Living in socal we dont get to much cold weather and i only drove it during good weather so i didnt need a heater. I forgot to turn the pump on and i got about 1/4 mile away before it ran out of gas thats when i remembered to turn the pump on.
my70chevyc10 is offline   Reply With Quote
Old 08-03-2007, 12:45 PM   #9
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
So if I do this, when I turn the key all the way to the right will it clean my windshield?
j/k .........Bamm
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 08-03-2007, 12:53 PM   #10
RedZ71
Junior Member
RedZ71's Avatar
that will work perfectly...
UNTIL A RAINY DAY!!!
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 08-03-2007, 12:56 PM   #11
Orange
Licensed to Thrill!
Orange's Avatar
Why wouldn't it work on a rainy day?
(I think you misread his original post).
DLB
Old 08-03-2007, 01:08 PM   #12
RedZ71
Junior Member
RedZ71's Avatar
DLB
then i shall revise...
"UNTIL SOMEONE TRIES TO STEAL IT ON A RAINY DAY!!"
Jonathan
1971 LB C10 Custom
Old 08-03-2007, 03:39 PM   #13
project1971
project1971's Avatar
i did something similar few years ago on my old mustang, ran the starter hot wire through the cig lighter, i don't smoke but if the element isn't pushed in or not there it wouldn't complete the circuit.
2008 Ford FX2 Screw
1971 C10 project in shop now!
2004 Pontiac Grandam (wifes)
2000 Cavalier z24 (gas saver)
project1971 is offline   Reply With Quote
Old 08-03-2007, 03:52 PM   #14
57sailplane
57sailplane's Avatar
the cigerette idea is awsome its like having 2 keys. exept everyone has a copy of the cigerette liter.
57sailplane is offline   Reply With Quote
Old 08-03-2007, 05:33 PM   #15
eedgell
It's the air up here
eedgell's Avatar
A main kill switch is a good idea. Just run the main hot to the switch first, before it goes into the cab. If the switch is off, everything is dead. The switch can be keyed as well. BTW, the switch can be mounted any where.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 08-03-2007, 06:44 PM   #16
Texasdeere
Texasdeere's Avatar
I ran a hidden switch on my old Trans Am. It cut the ingition power lead to the HEI. So you could crank all you wanted to, and it wasn't going to start. Unless the switch was in the "on" position.
Texasdeere is offline   Reply With Quote
Old 08-03-2007, 06:56 PM   #17
1LoC10
Insert Title Here
1LoC10's Avatar
or put a windshield squirter in the choke hole, and when they go to strat it, it squirts in there eye
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 08-03-2007, 07:08 PM   #18
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
A theft deterent is probably a good idea.Just think about it.A theif can carry a new switch set up and just unplug and plug in his switch,then he has a key.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-03-2007, 07:11 PM   #19
MisterE72
Keep Your Nose Clean
my idea of theft deterant.
MisterE72 is offline   Reply With Quote
Old 08-03-2007, 07:23 PM   #20
70' GMC
HERE.......Somewhere
70' GMC's Avatar
try this http://www.4mysecurity.com/
if that wont work get the shotgun
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 08-03-2007, 07:24 PM   #21
BurnoutNova
BurnoutNova's Avatar
wouldnt it be possible to just unplug the harnesss from the back of the ignition switch, and plug anotherone into it... to steal a truck?
if someonw knew there way around these trucks anyway
BurnoutNova is offline   Reply With Quote
Old 08-03-2007, 07:25 PM   #22
70' GMC
70' GMC's Avatar
or you could do it like this
Old 08-03-2007, 07:50 PM   #23
jerry moss
Born Psycho
jerry moss's Avatar
i use a stainless steel Ruger 44 magnum with a scope.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 08-03-2007, 09:06 PM   #24
CG
BlahBlahBlah
Get yourself one of those easy buttons, set it on the seat and wire up to a crazy loud siren or one of those sets of train horns. One click on, has to be turned off with a hidden toggle or something. Thief breaks into your ride, sits down on the seat and looks over "cool, an easy button"...NO ONE can resist pushing one of those easy buttons ...*click*... he sets of the alarm
Old 08-03-2007, 09:16 PM   #25
msgross
msgross's Avatar
funny and true
How about a proximity sensor? Not the cheapest but very high tech...
Microwave Detectors: A type of proximity sensor that triggers when an object enters the sensors zone of protection. These sensors are very popular with open vehicles such as convertibles and Jeeps.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
