Old 08-05-2007, 10:57 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Water out of my exhaust...
New truck, I've got water coming out my exhaust. I knew I'd have to replace the motor, but I was hoping I'd have a little more time. Am I right in thinking it's the head gaskets? Big wet spot out of both sides...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-05-2007, 11:00 PM   #2
Premium72
Premium72's Avatar
Re: Water out of my exhaust...
uh, no. should be okay. its just condensation from the the pipe getting hot. unless you have gallons of water coming out and your radiator is emprty , you should be okay. but hey maybe im wrong.
Premium72 is offline   Reply With Quote
Old 08-05-2007, 11:17 PM   #3
corn
Your engine produces something like 8 pounds of water vapor for every gallon of gas it uses. Exhaust systems rust from the inside out...
corn is offline   Reply With Quote
Old 08-06-2007, 12:24 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
Thanks for the replies. What a relief. I've only had the truck a few days, and hadn't noticed any water before. Radiator is full. I'll try it again tommorow morning and see how it is. Thanks again...
Beat it to fit,
Old 08-06-2007, 12:32 AM   #5
Morgsie
H2O: a byproduct of combustion, imagine that?
Morgsie is offline   Reply With Quote
Old 08-06-2007, 12:46 AM   #6
Sinister
Between Trucks...
Sinister's Avatar
Well, this seemed like quite a bit of H2O...
Beat it to fit,
Old 08-06-2007, 06:55 AM   #7
70c10
67-72 Addict!
70c10's Avatar
I fired my truck up last night for the first time in several months and had alot of water droplets all over the floor of the garage on both sides.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-06-2007, 08:08 AM   #8
Premium72
Premium72's Avatar
just to be clear i was sorta bein a smart @ss about the whole empty radiator thing.
Old 08-06-2007, 08:27 AM   #9
Mudder
Mudder's Avatar
Keep an eye on the water level in the radiator. If it goes down it could be the gasket or a cracked head.
Mudder is offline   Reply With Quote
Old 08-06-2007, 09:26 AM   #10
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
also, check the oil to see if has water in it.
OlChev67 is offline   Reply With Quote
Old 08-06-2007, 10:20 AM   #11
grayw0lf
I second the "keep an eye on it."
Also, take your radiator cap off & watch for bubbles. They should settle out in a few minutes.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 08-06-2007, 12:14 PM   #12
Sinister
Between Trucks...
Sinister's Avatar
I'll keep my eye on it. Seems weird though, water out of both sides. Not a lot, but more then looked "normal". What are the chances of both head gaskets going south, or cracking both heads at the same time? I'll check it out today sometime and see what's up with it...
Beat it to fit,
Old 08-06-2007, 12:50 PM   #13
2bits
2bits's Avatar
You'd be blowing blue smoke too probably if you were burning water I think, at minimum the oil would be chocolate milk, if those things are good, then, you are good
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 08-06-2007, 02:12 PM   #14
Sinister
Between Trucks...
Sinister's Avatar
I went to change the oil this morning. No water in the oil, but the person who put the oil filter on last put it on so tight, I couldn't get it off. Put a crack in the filter, had to get down to the corner gas station and pay for an oil change.
I think the water might have been condensation or something, seems alright today...
Beat it to fit,
Old 08-06-2007, 04:55 PM   #15
Ironhead
Ironhead's Avatar
...It's not for everyone but, if you're running anti-freeze, a sure way to tell you got a problem is to get a drop of the condensation from your tailpipe on your finger and stick it on the end of your tongue. There is no doubt you'll recognize the taste of anti-freeze.
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
'97 Silverado Ext. Cab
Ironhead is offline   Reply With Quote
Old 08-06-2007, 07:03 PM   #16
rmoorhead
rmoorhead's Avatar
No offense ironhead but thats just nasty yo
sometimes after a good run some water will form at the oil filler cap.
same chocolate milk color but just a little spot.
4life
rmoorhead is offline   Reply With Quote
