Old 08-06-2007, 01:20 PM   #226
shifty
Questionable
shifty's Avatar
Re: Killers 5.3L install
Originally Posted by 68 short step View Post
well from now on this is my full time job...
in case you need some thoughts or ideas, or seeing how others are doing it:
http://www.nahrods.com/products/index.php
note his pricing and options at the bottom. overally, very reasonable - that is a bit of a tougher install, but ... prices are very reasonable. you could seriously use that general concept as a business idea for yourself.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-06-2007, 01:29 PM   #227
68 short step
thanks shifty, ill have to use that idea.
68 short step is offline   Reply With Quote
Old 08-07-2007, 09:57 PM   #228
68 short step
got the frame and suspension back from the powdercoaters....
Old 08-07-2007, 10:00 PM   #229
killer71
killer71's Avatar
I thought we were goin with "cloud blue"...and where is my jackstand?
I think they turned out nice...
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 08-07-2007, 10:02 PM   #230
killer71
killer71's Avatar
Is that 4 sale sign intended for your estate or Killer?
R.I.P.
Killer 71
10/26/07
Old 08-07-2007, 10:06 PM   #231
gringoloco
A guy with a truck
gringoloco's Avatar
Looks good. Hurry up and send her back to Shreveport so I can see it in person. Not running the exhaust through the crossmember?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-07-2007, 10:18 PM   #232
68 short step
killer comes with the estate....
Old 08-07-2007, 10:20 PM   #233
68 short step
no, we want the e-brake functional... the exhaust would interfer with the cable.... also at first we didnt plan on doing a drop, now we are.......
Old 08-07-2007, 11:30 PM   #234
oscareltemblo
oscareltemblo's Avatar
Everything looks nice .... EYE Candy.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844
oscareltemblo is offline   Reply With Quote
Old 08-08-2007, 10:26 PM   #235
68 short step
started assembling the frame today...majority of the day i spend cleanig steering parts and cleaning/ sanding brake lines... the new rear ECE trailing arms are SWEET, they are totally boxed and are a heavy guage, i know this cause they are HEAVYYYYY..... installed front x-member, trailing arms, fuel lines, brake lines... also brought over a buddy of mine to lend his hand on the cab...
Old 08-08-2007, 10:30 PM   #236
killer71
killer71's Avatar
Nice work don...i was hoping for some updates! While i'm thinkin about it...what differential fluid will you be using?
R.I.P.
Killer 71
10/26/07
Old 08-08-2007, 10:56 PM   #237
68 short step
80/90 castrol, do you have a preference?
Old 08-09-2007, 01:00 AM   #238
Ackattack
Ackattack's Avatar
The powdercoating looks great!
I read the entire thread for about the 3rd time looking for this, so forgive me if its been answered.
Where did you get the engine stands, mounts, and adapters from?
Ackattack is offline   Reply With Quote
Old 08-09-2007, 08:44 AM   #239
killer71
killer71's Avatar
A lot of guys are using synthetic and was wandering?
R.I.P.
Killer 71
10/26/07
Old 08-09-2007, 09:21 AM   #240
68 short step
ok will do, do you have a brand prefrence, and pennzoil is not a option!!!!
Old 08-09-2007, 09:24 AM   #241
68 short step
http://www.performanceonline.com/sto...cat=455&page=1
Old 08-09-2007, 09:40 AM   #242
killer71
killer71's Avatar
I wanna say use synthetic as i believe that's what was in it...but i'll check with my guy who filled it and let you know what was in it before u drained it!
R.I.P.
Killer 71
10/26/07
Old 08-09-2007, 12:34 PM   #243
Spanky_Pete
Too many trucks? Nah...
Spanky_Pete's Avatar
Fantastic progress on this build, as usual. I am quite envious of how that frame looks.
Spanky_Pete is offline   Reply With Quote
Old 08-09-2007, 02:47 PM   #244
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Looks nice. I might have to plan another stop by your place to check it out
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 08-10-2007, 03:31 PM   #245
68 short step
getting some more assembly stuff done, while waiting on the suspension stuff to arrive...
got the steering box, intermittent shaft, ideler arm(still need to add washers under the head of the bolts), tie rods painted and installed, trans cooler on, and fuel cell mounted and plumbed..
Old 08-10-2007, 05:57 PM   #246
Ackattack
Ackattack's Avatar
Man, this is the fun part! Get to see it all come together!
Old 08-10-2007, 09:24 PM   #247
killer71
killer71's Avatar
Fabulous work my good friend...any updates on the cab?
R.I.P.
Killer 71
10/26/07
Old 08-10-2007, 10:37 PM   #248
68 short step
the cab will be getting painted tomorrow... im gonna locate the bulkhead connection tomorrow, then do a little more final sanding then shot it... i get some more pics of it tomorrow...
Old 08-10-2007, 10:49 PM   #249
meathead95
computer illiterate
meathead95's Avatar
what is the can just outside of the feul tank 2 lines in and 1 out
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 08-10-2007, 10:54 PM   #250
Hart_Rod
Hart_Rod's Avatar
Fuel pump/fuel pressure regulator.
Hart_Rod is offline   Reply With Quote
