Old 08-06-2007, 06:02 PM   #1
houghda
Brake Lights and turn signals
Got a 67 GMC with a small issue. The brake lights work. The turn signals work. The brakelights do not work when the turn signals are in use. Obviously one would blink, but the other should light. My experience would say replace the switch in the column. Any better ideas?
houghda is offline   Reply With Quote
Old 08-06-2007, 06:10 PM   #2
zeeklu
Re: Brake Lights and turn signals
I agree,probably the turn signal switch. I had the same problem. Chris
zeeklu is offline   Reply With Quote
Old 08-06-2007, 06:13 PM   #3
houghda
can I ask...where is the best place to buy switch (on the east coast)?
Old 08-06-2007, 06:31 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
any parts store should have it. Make sure to check for an adapter in the box with the new switch.
Old 08-06-2007, 06:32 PM   #5
Longhorn Man
Correction... any parts house should BE ABLE TO GET IT.
Old 08-06-2007, 06:32 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
First make sure the bed is grounded to the frame good. I had the same problem, all I did was add a ground strap from the bed to the frame and that fixed it.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-06-2007, 07:23 PM   #7
Longhorn Man
good idea... highly unlikely being the ground will support the load of both brake lights being on... not likely to only be able to support one steady burn and oone on and off burn... but, it CAN happen.
Old 08-06-2007, 07:28 PM   #8
68 Stepside
huh?
68 Stepside's Avatar
First thing that came to mind here is turn signal switch. My 67 panel did the EXACT same thing.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 08-06-2007, 07:52 PM   #9
truckdude239
truckdude239's Avatar
http://www.manestruckparts.com/store...&Category_ID=8
here is an oe replacement i used one for advance auto and it has the new hazard button and i hate it
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 08-07-2007, 12:05 AM   #10
GMCMAX
Active Member
GMCMAX's Avatar
Squirt WD40 or similar in the gap under the steering wheel to column to get to the t/s switch, work the switch fast back and forth a bunch: the old grease and stuff will break up and the contacts can connect.
Done this on the 68 a few times...
Easier than a switch replace and a lot cheaper too.....
Max
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 08-11-2007, 03:22 PM   #11
houghda
Thumbs up Re: Brake Lights and turn signals - FIXED!!
Thanks guys
It was the switch...............
Grounded the Bed first, glad I did.
