Old 08-07-2007, 12:05 PM   #1
Jwill41
Jwill41's Avatar
a/c control levers
I think I got a problem. I ordered new a/c control levers as one of mine is broken. I looked at it last night and am puzzled for what to do. The shaft that the levers rotate around is held in place by a steel plate. This plate is set on two pins which are "hammered" flat to hold it in place. It looks like I need to grind off the pins to remove the plate and then the levers. All is good to this point. The problem is I dont know how I will hold the plate in place after re-assembly. This was much easier on the 68 which has heat only. I know this is probably hard to understand but if anyone does understand and has a solution, let me know. I may try to post a pic later to help explain.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-07-2007, 12:25 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: a/c control levers
This was the only way I figured you could to it...
http://67-72chevytrucks.com/vboard/s...d.php?t=245558
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-07-2007, 12:58 PM   #3
Jwill41
Jwill41's Avatar
thanks. That is exactly what I was talking about. I had thought about using screws but thought there might be another way. thanks again, very helpful.
