08-14-2007, 08:36 AM | #1 |
Dual horns picture
Has anyone got a picture of where their two horns are located by the rad support.
I swear, I can not find where teh rad support mounted horn is supposed to go, but I have two of them and the harness, so they must fit somewhere. Anybody recall if they hava a picture in their stash that shows the 2 OEM locations?
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
08-15-2007, 02:11 PM | #2 |
Re: Dual horns picture
ttt
08-15-2007, 02:35 PM | #3 |
Here ya go...
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
08-15-2007, 02:41 PM | #4 |
Long Fleet Club
I mounted my horns here
Really wish I could help my PO mounted my single horn here
Chris Meeks '69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling. Truck is now finished to the new owners design and running around. I was shown some pictures of the finished product. At least it survived the junk yard. FAQ Index by Krue Site Vendors Subscribe Here Forum Rules |
08-15-2007, 03:12 PM | #5 |
Without a picture the best I can do is describe where I pulled the dual horn set up off of my core support,... There are two tapped holes 5/16nc in some welded on tabs that are real close to the stock volt regulator mount just below the left headlamp. Look there. The harness was such that there is still only one plug as for a single horn, but I believe like a jumper was there between the 2 horns. It has been several years ago that I pulled them from the junk yard.
Good luck. |
08-15-2007, 03:24 PM | #6 |
Long Fleet Club
here is a pic of where he was describing. The only one I have. You might be able to see it.
08-15-2007, 03:26 PM | #7 |
Long Fleet Club
well I guess not. But how do you like the PO wiring
08-19-2007, 12:38 AM | #8 |
Chuck - the basic horn (single only) bolts to the weld nut showing in cameeks post # 6. It is at the same level as the bottom of the VR. The optional horn (dual) mounts to the weld nut as shown by Chad in post #3. It is at about 7:30 o'clock from the center of the headlight and can be seen where the horn wire goes/\.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow Last edited by Bob Moore; 08-19-2007 at 12:45 AM. |
08-19-2007, 01:07 AM | #9 |
What the ..........??????
08-19-2007, 01:11 AM | #10 |
mtnmanchad,,,,, Hey there, is that a second bat tray I see in Post 3 or nwhat the Hey is it?????
08-19-2007, 01:14 AM | #11 | |
08-19-2007, 03:28 AM | #12 |
Neighborhood Pickle Slinger
Here is where mine is. I think that is the original spot for it.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
08-19-2007, 02:19 PM | #13 |
prg machine - the weld nut is even with the parklight wires going through the core just to the right.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
08-19-2007, 03:00 PM | #14 |
its all about the +6 inches
08-20-2007, 01:52 PM | #15 |
Hey there all - thanks for all that constructive input. I got confused cus I had the aux. battery tray and it was using the lower bolt on the rad support. I did not think the horn would share it.
Great input. Thanks
08-21-2007, 08:35 PM | #16 |
OK, here's a photo of the duel horn setup. I'm thinking since I'm the 3rd owner of this family farm truck Father, bought it new, son had it up to about a month ago and I bought it. Here's the photo. Hope this helps! Oh ya this is a 71 Longbox Cheyenne
08-21-2007, 10:35 PM | #17 |
08-21-2007, 10:50 PM | #18 |
How long ago was that prg?
08-21-2007, 11:03 PM | #19 |
HERE.......Somewhere
the easiest way to do it is........ have the hood raised and then have someone on the inside of the cab and mash the horn button and you will find em and when you pull that stunt make sure you have some aspirin
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
