Old 08-14-2007, 02:02 PM   #1
swiny20
72 pickup brake pedal goes to floor
Ok,(72 disk/drum) try to make this short, bought truck knowing it had rear wheel cylinder leak, assuming this was also related to pedal, I have since replaced rear wheel cylinders and brake shoes. I have bled and bled these things (all 4 corners), but no change in pedal, with little resistance it just goes to the floor. I'm new to this site, but I would appreciate any advice. Things I have checked from reading other post. Brakes are adjusted so drums barely go on, combo/poportioning valve button(?) pushed in., and bled the @#it out of them.
swiny20 is offline   Reply With Quote
Old 08-14-2007, 02:26 PM   #2
truckdude239
truckdude239's Avatar
Re: 72 pickup brake pedal goes to floor
master cylider has gone bad
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 08-14-2007, 03:08 PM   #3
Chevyholic
Will it run today?
Chevyholic's Avatar
I recently had a similar problem. No leakage anywhere, but the brakes just kept getting worse. Finally pulled the MC and found that it was leaking back into the booster. Replaced the MC and all is well again.
Good luck!
Jaws, the 1971 Chevy Cheyenne Longbed.
She's big, grey, and has an insatiable appetite!
Chevyholic is offline   Reply With Quote
Old 08-14-2007, 11:16 PM   #4
truckdude239
if it is leaking into the booster always replace the booster
David fuller
2000 Tahoe 5.3l 378
Old 08-15-2007, 12:00 PM   #5
swiny20
Thanks guys, I put it on yesterday and their is a difference now I just need to re-bleed all four corners.
Old 08-15-2007, 12:51 PM   #6
cdowns
cdowns's Avatar
just clamp the pin on the combination valve like it says in the service manual and the bleeding will go smoothly
Old 08-15-2007, 02:57 PM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
Make sure you bleed the new M/C as per the instructions that usually come with one. There's a cheap little kit you can buy for like $4 with hoses and clips that make it really easy too.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-15-2007, 06:11 PM   #8
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
good luck and WELCOME to the board. Remember WE LIKE PICTURES !!
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
