08-18-2007, 01:15 AM | #26 |
Luv the Crewcabs
Re: Dropped Longbed's, Need Some Pics........
The 3/5 Combo look's Good on these Trucks, I think that will be the way i will go if i do it................
Really Like these Rim's , 20" With a 285 size Tire, They are 6 lug off a 2002 Yukon. Anybody know if these would fit our Trucks? Thanks, Rick |
08-18-2007, 01:18 AM | #27 |
Sophomore Member
bolt pattern is same, don't know if offset would work, that's an awful tall tire, but they look worn so if you could get em right you could get new tires.
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
08-18-2007, 01:28 AM | #28 |
The offset will be off (they will sit in too far) and the factory wheels' centerhole is too small to fit over the hub on our year trucks. An aftermarket like these may be okay, but a factory wheel would have to be machined to make hole large enough to clear.
The place where you made your stand never mattered. Only that you were there... and still on your feet.
Stephen King |
08-18-2007, 03:55 PM | #29 |
70+ ( Old Skool Club )
That is the stance I like. I am going to drop mine 3 1/2 FRT and 5 RR. What are the tire sizes front and back on your truck?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
