Old 12-23-2002, 02:39 AM   #1
redneck_chev
Unhappy Brake light stays on?
Hey fellers
My brake light on the dash stays on. How can I fix it. I crawled underneath the truck but couldn't see no leaks. It stops as good as always. It has drums all around it. I put a new master cylinder on about 5 months ago. So I don't know what is causing the light to stay on!
Any help would be a great help.
1967 Chevy C-10 fleetside
SB 3speed on column
Corvette yellow#35 Black W/Red Metal Flake int. looks like Black cherry
Diamond White Pearl /Grille
Jenson CD system
Wooden bed
redneck_chev is offline   Reply With Quote
Old 12-23-2002, 05:45 AM   #2
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
did ya check the fluid level in the master cylinder, or the wire that hooks to the prop. valve?
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 12-23-2002, 12:44 PM   #3
wlee
Just an Old Mr Goodwrench
You may have some air in the system from the M/C replacement, but your problem should have shown up sooner than 5 months - more likely it's the proportioning valve
1969 CST 20 Longhorn
1970 CST 20 Fleetside
1991 Jaguar Sovereign
1992 Mazda Miata
wlee is offline   Reply With Quote
Old 12-23-2002, 01:41 PM   #4
ckhd
ckhd's Avatar
Has it been on since before the MC change 5 months ago, or is the light a recent thing?
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 12-23-2002, 05:27 PM   #5
redneck_chev
Smile thanks for the help!
I have check the levels. They are o.k. The wire seems to have good connection.
If there is air in the propotion valve. How can I get it out By myself.
The light is a recent thing. How hard is it to replace the p/v.
SB 3speed on column
Jenson CD system
Wooden bed
Old 12-23-2002, 07:31 PM   #6
john
member #16
john's Avatar
If it is the p/v the light should go out when you unhook the wire. I would bleed the brakes again and see if the valve centers itself.
john is offline   Reply With Quote
Old 12-24-2002, 12:17 AM   #7
Don Smith
Try pushing on brake pedal hard (approx. 100 lbs ) this should reset piston in proportioning valve which is probably causing light to stay on.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 12-24-2002, 12:40 AM   #8
junkyardjohn
junkyardjohn's Avatar
Thumbs up
IF YOUR FLUID LEVEL IS GOOD, & YOUR PEDAL IS HARD & NOT SPONGEY, TRY STOMPING ON YOUR PEDAL (KINDA LIKE A PANIC STOP) & IT WILL PROBABLY RESET YOUR PROP. VALVE. LET ME KNOW IF THIS WORKS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 12-24-2002, 01:22 AM   #9
71Custom10
71Custom10's Avatar
I had the same problem. Good brakes but the light stayed on. I replaced the sensor that the wire goes to with one from a parts truck and that fixed the problem. The light now comes on when I start the truck then goes out. Andrew
'67 Chevy Longbed Fleetside - Daily Driver(For Now)
'72 Cheyene Longbed Fleetside-Daily Driver
Best Towing Service
71Custom10 is offline   Reply With Quote
Old 12-24-2002, 11:22 AM   #10
Bernie
I had the same thing with the light. I thought there had been no fluid loss, but when I pulled the drums I found a bad wheel cylinder. Just leaked enough apparently for the light to come on.
Bernie
Bernie is offline   Reply With Quote
Old 12-24-2002, 12:31 PM   #11
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
My breaks were horrible and the only time my light came on was when my emergency break pedel slipped down.
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 12-24-2002, 02:21 PM   #12
redneck_chev
Talking Thanks Guys It Fixed It
Well I pushed the pedal real hard and real quick.
Then unpluged the wire . Then pluged it back up. The light went out. Now it comes on when I start the truck then it goesout . Like it is supposed to do.
But as soon as I can get in the garage. I will check the wheel cylinders again. For any leaks. Once again
"THANKS FOR ALL HELP" I couldn't do with out you guys.
redneck_chev
SB 3speed on column
Jenson CD system
Wooden bed
