Old 08-21-2007, 10:55 PM   #1
mvfd70
mvfd70's Avatar
Trucks stop better when the brakes work.
Well I had an interesting time this morning. I got off work and was driving across town to go home with all intentions of getting out in the garage and working on the 68. I just got the rear end of it rebuilt and had to pick it up today too. Anyway, as I got about half way through town I was braking for a stop light. All of a sudden the brake pedal hit the floor!!!! I did the natual thing and pumped it. That got enough pressue to get me stopped for the light. Luckily I was right in front of an O'Reilly's. That couldn't have worked out better. There was brake fluid all over the drivers side of the rear axle and frame. I went inside bought a can of brake fluid and refilled the master. Didn't have any tools of any kind on me what-so-ever so I limped it back to work using the E-brake to stop (that was fun). Fortunately the fire department I work for does all in house maintenance on our trucks so I had plenty of tools. But I had to spend the next couple hours changing the brake line. This was on the 97 GMC Z71. That thing was a bear to get to. It was the line that runs to the back two wheels. For those that don't know where it runs, it runs along the inside of the frame rail between the frame and gas tank. And of course the front fitting for that line is right between the gas tank and frame. You gotta be a freakin contortionist to get to it. But it's fixed, I didnt have an accident, and I got the rear axle for the 68 back home ready to put the shafts in and put on the truck.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 08-21-2007, 10:57 PM   #2
mvfd70
mvfd70's Avatar
Re: Trucks stop better when the brakes work.
Oh by the way, the busted line didnt just spring a leak. It almost snapped in half. Still don't know why GM used a plain steel line there instead of stainless.
Old 08-21-2007, 11:01 PM   #3
AlienYouth
AlienYouth's Avatar
that happened to me, but i hit a building and totalled my truck, guess u got off a lil better : )
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 08-21-2007, 11:10 PM   #4
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
Lucky, you got it stopped and glad your safe.
1967 K20 400TBI SM465/NP205
posi front, Detroit locker 4.56 rear
ND_guy is offline   Reply With Quote
Old 08-22-2007, 12:30 AM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
brakes are overrated
glad everything turned out alright and you got it fixed
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 08-22-2007, 07:43 AM   #6
72armyswbtruck
72armyswbtruck's Avatar
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-22-2007, 11:22 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
[QUOTE=I limped it back to work using the E-brake to stop (that was fun). QUOTE]
What is an E-Brake????? I got the pedal, but never had it do anything but satisfy the MSHA inspector if he looked inside it to see if it was set.
Glad you didn't have any serious repercussions.....oh, thank God for O'Reilly's, huh?
Member Nr. 2770
Old 08-22-2007, 11:58 AM   #8
mvfd70
mvfd70's Avatar
I never realized how hard it was to stop using only rear drums on a pick up before. Interesting experience. Especially in heavy traffic.
And yeah thank goodness for O'reilly's. What luck that that would happen right in front of any parts store. I wouldn't have messed with refilling it but i wanted some fluid to keep some pressure in case I needed to stop quickly for some reason. It pissed people off that I was driving slow but not being able to stop sucks.
Old 09-12-2007, 05:49 PM   #9
jc1969c10
jc1969c10's Avatar
Glad your okay MDF70.
I have a similar problem, but it happened after I had to change out the gromet on the vacuum hose. After putting in the new grommet and attaching the hose, I cranked her up and now have no brakes. What could have happened? The brakes were fine before I replaced the grommet. It was bad and leaking so I had to replace it.
Any ideas would be greatly appreciated.
jc1969c10 is offline   Reply With Quote
