Old 08-13-2007, 02:21 AM   #1
fastbagged68
fastbagged68's Avatar
Is a Suburban frame the same as a long bed?
Does anyone know if a suburban frame is the same as a long bed? I am thinking about selling my frame on my 63 and building a new one to do coil overs on...Any help guys would be appreciated!!!
fastbagged68 is offline   Reply With Quote
Old 08-13-2007, 06:56 AM   #2
earl87gta
earl87gta's Avatar
Re: Is a Suburban frame the same as a long bed?
I know on the 67 to 72 trucks there the same other then a body mount or 2 but nothing major I would be the same.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 08-13-2007, 05:02 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
Couldn't tell ya on a 63, but Click Here for 67-72 differences.
Frizzle Fry is offline   Reply With Quote
Old 08-13-2007, 05:36 PM   #4
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
if i remember correctly, the burb is same as short wheelbase pickup 115" or so in those years.
milehightoyz is offline   Reply With Quote
Old 08-14-2007, 05:37 PM   #5
fastbagged68
I don't think my frame is the same as a short wheel base. I am working on a 68 suburban now. I will look under the frame tonight to see if it is the same as my 63. Edited by Moderator. Nothing wrong with it.
Old 08-15-2007, 03:21 PM   #6
Frizzle Fry
I thought the 60-66 panels came in short or long and the subs were all long
Old 08-16-2007, 01:19 PM   #7
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
As I recall the 60-66 suburbans were built on frames that had a 115 inch wheelbase.................the short bed pick-ups also used the same wheelbase................................the long fleetside pick-ups, the long stepside pick-ups and the extended panel trucks were built on 127 inch wheelbase frames........................Obviously the 60-62 trucks had the torsion bar front suspension and aren't that desirable to swap to.....................................the suburban frames just had different body mount points ........................hope this helps clear it up for you................hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 08-16-2007, 04:19 PM   #8
Frizzle Fry
I can see from the side view in you avatar Demmit that it's definately not a long wheelbase. Fastbagged's looks long, but it must be because it's sitting on the ground.
Old 08-16-2007, 04:40 PM   #9
fastbagged68
So the frames are the same, just different body mounts? Is the tail section longer on a suburban? Learned something new today!!!!
Old 08-22-2007, 09:08 PM   #10
mike409
mike409's Avatar
i am doing a 72 burb and used a 87 long bed and had to move rear up 4" there are factory holes in the frame for the rear hangers i had to make frame mounts the wheel base is 128" also on a burb frame it is strait from first cab mount to front of back tire and on pickups it is humped up so you need to make mounts and truck frame is 6" shorter at rear will have better pics soon have frame mounts done and rear moved up will have closeups
mike409 is offline   Reply With Quote
Old 08-22-2007, 09:48 PM   #11
qksilver
I measured my 65 burb and my 66 SWB. Not accurate but the wheel bases and frame lengths are different. Both my truck are apart and stacked with parts against them so I can't give you actual measurements.
qksilver is offline   Reply With Quote
Old 08-22-2007, 09:48 PM   #12
krue
Designated A-hole!
krue's Avatar
If you want to sell it you need to subscribe and post it on the parts board. For info on subscribing, click the "support the board" link in my sig.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
