Old 08-23-2007, 06:49 AM   #1
truckn'
truckn''s Avatar
65rhinoframe
has anyone rhino lined their frame or had it sprayed by linex before assembly. any reason why this wouldn't look good or work mechanically? other than frame being 1/8" thicker does anyone forsee any problems. pgf.
truckn' is offline   Reply With Quote
Old 08-23-2007, 11:48 AM   #2
is2blu
is2blu's Avatar
Re: 65rhinoframe
I am not certain about the size part with parts fitting but I am certain that you will have an issue with drilling holes and redrilling the predrilled holes unless you fill them all prior to spraying. On the underside of my cab we had a time mounting the seat because the holes were filled with rhino and it is tough to drill through. just a thought
keep on truckin',
gaileen
is2blu is offline   Reply With Quote
Old 08-23-2007, 12:02 PM   #3
satin64
satin64's Avatar
Re: 65rhinoframe
i wouldnt use it under anything.when it gets damaged it flakes off in big pieces.i used it under a wagon i built and regretted it a couple years later.i would powder coat the frame.as far as on cab parts i would use lizard skin on the outside.
http://www.lizardskin.com/
satin64 is offline   Reply With Quote
