Old 08-23-2007, 01:13 PM   #1
Peter82
Everything is Custom
Peter82's Avatar
Question Running too rich... please help
My truck is running too rich... My buddie said that the carb can be adjusted by the front 2 screws to lean out the mixture but he didnt remember how to do it. He said something about screwing them both in all the way and back them out like 4 times. Any one know the real adjustments???
Peter82 is offline   Reply With Quote
Old 08-23-2007, 06:33 PM   #2
High Speed low Drag
High Speed low Drag's Avatar
Re: Running too rich... please help
Screw both all the way in. Back them both out about 2 1/2 turns. That should get you in the ball park. Play with it from there.
High Speed low Drag is offline   Reply With Quote
Old 08-23-2007, 07:53 PM   #3
corn
When you turn them in, just seat them. Dont ever tighten an idle mixture screw. Ive always started at 1 1/2 turns out but Im used to Holley's...
corn is offline   Reply With Quote
Old 08-23-2007, 07:56 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
^Do you mean don't ever "over"tighten an idle mixture screw?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-23-2007, 08:10 PM   #5
corn
Yep, exactly. When it stops, quit. The mixture screw has a sharp point on it that seats when closed. If you get carried away screwing it in, you will end up screwing it up.
Old 08-23-2007, 08:26 PM   #6
67ChevyRedneck
Never knew that. I was always "gentle" with mine
I think I have mine set at 1 3/4 and my truck runs good. My timing is also set to 12 deg btdc.
Jesse James
Project "On a Dime"
Old 08-23-2007, 08:30 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
"Screwing it up" for these adjusters happens when you turn them and bottom them out. When it happens over and over, or if it is done with enough force, i.e., screwing them until you can't possibly turn them anymore, the result is that there will be these nice little grooves that go all the way around the pointed end of the adjusting screw. The resulting action is that you can't ever get the idle air adjusted because the air goes to the point of least resistance, and that groove is a permanent place for the air to go.
Just turn them until they barely stop turning. Then, back them out. I always did 2 turns on a Rochester.
But I see you have an Edelbrock. If it is an 1406, with a manual choke, it is jetted from the factory with .100 main jets. It will be rich. There are other jets that you can get, so that may be the way you have to go. Look at www.edelbrock.com and find the carb tech section. It will give you a lot of info that may be of help.
Member Nr. 2770
Old 08-23-2007, 09:15 PM   #8
jkade
jkade's Avatar
I would say get used to it with that edelbroke unless you change jets
jkade is offline   Reply With Quote
Old 08-23-2007, 10:52 PM   #9
Peter82
Peter82's Avatar
Thanks guys... i am going to check out the web site first and if they dont give me what i am looking for i will try and adjust them... i am so glad you guys know so much about these trucks. i dont know crap about them. thanks
Old 08-23-2007, 11:33 PM   #10
72armyswbtruck
72armyswbtruck's Avatar
Give yourself some credit now you know how to adjust the airflow fuel mixture on the edelbrock carb...
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-23-2007, 11:51 PM   #11
tx71smallblock
tx71smallblock's Avatar
the manuel for mine says to tighten one untill the motor starts to sputter then back out about a half to a full turn, then do the other the same way. but it also says that these have nothing to do with the running mixture just the mix at idle.
70 Chevy C-10 short step
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
tx71smallblock is offline   Reply With Quote
Old 08-23-2007, 11:52 PM   #12
tx71smallblock
i also noticed u dont have ur pcv valve hooked up, why is that?
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 08-24-2007, 12:29 AM   #13
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
I´m going to start mine today for the first time after the restoration.
It was running rich before too. It has a 1407 (750 CFM) on a 327.
Way too big for the engine but don´t have the money for a different one.
Our mechanic said see what it does after the restoration and maybe we can change the needles to step it down a little.
Thanks for the infos on the Idle screws. I will try that.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 08-24-2007, 12:51 AM   #14
Peter82
Peter82's Avatar
Yea... i got the truck for $750 and all i did was change the spark plugs and add a new battery, add some tranny fluid, change the oil and the diff fluid. i really dont have any idea where stuff goes and what is really missing. i will be ripping the engin out next spring and re-do everything. what will the PCV valve do for me?
Old 08-24-2007, 01:09 AM   #15
blukangoo
blukangoo's Avatar
The Positive Crankcase Ventilation valve, or PCV valve, is a one-way valve that ensures continual refreshment of the air inside a gasoline internal combustion engine's crankcase.
My C10 Diary
Our cars:
Old 08-24-2007, 02:39 AM   #16
GREASEMONKEY72
GREASEMONKEY72's Avatar
PCV valve sucks in the unburned fumes and different gasses out of the crankcase and reburns them, basically its an emissions deal and ive heard you get better mpg with it hooked up
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 08-24-2007, 02:51 AM   #17
brak
brak's Avatar
Here's a little known fact: PCV was actually invented back during WWII for use on tanks, to keep water out of the crankcase.
Here's my favorite definition:
As an engine runs, gases from the cylinders leak past the piston's sealing rings into the crankcase (containing the crankshaft and other parts). This leaked gas is sometimes referred to as "blow by" because the pressure within the cylinders "blows" them "by" the piston rings. These gases include compounds harmful to an engine, particularly hydrocarbons (unburned fuel), as well as carbon dioxide and water vapor. If allowed to remain in the crankcase, or become too concentrated, the harmful compounds will condense out of the air within the crankcase and form corrosive acids and sludge on the engine's interior surfaces. This can harm the engine as it tends to clog small inner passages, causing overheating, poor lubrication, and high emissions levels. To keep the crankcase air as clean as possible, some sort of ventilation system must be present.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 08-24-2007, 09:29 AM   #18
jkade
jkade's Avatar
I would say that you really need a vaccum guage to adjust the carb the right way. I may be wrong
Old 08-24-2007, 10:51 AM   #19
cdowns
cdowns's Avatar
alot of good advise for adjusting carbs
my questions are what makes you think its running rich?? what do your sparkplugs look like?? what does the exhaust look like and smell like??
you just gotta love that rubber fuel line runnin right near the exhaust manifold KABOOM
Old 08-24-2007, 03:21 PM   #20
neonlarry
neonlarry's Avatar
If its RUNNING rich adjusting those screws are not going to help you any. Those are idle mixture screws, if its ideling rich adjusting those will help. But they won't do a thing for anything off idle. That will have to be done like said above by changing jets etc.
And yes, get rid of that rubber fuel line.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-25-2007, 12:39 AM   #21
tx71smallblock
although advised, u dont have to get rid of the rubber fuel line. u can just reroute it in a better position with an edelbrock "banjo" fitting for the fuel inlet on the carb.
250/3 on the tree
Owned:
71 longbed Cheyenne
70 swb
Old 08-25-2007, 09:39 PM   #22
Peter82
Peter82's Avatar
well the exhaust looks kind of black and it smells like sweet candy... it smells rich. you know, like rich exhaust fumes.
that fule line dosnt really run right near the manifold... it just looks like it. but is what you guys didnt really see is that i have a glass fuel filter... yea, i need a new one.
Thanks for the help guys.
Old 08-25-2007, 09:47 PM   #23
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
When I replaced my Edelbrock 1406 (manual choke), which was running rich, with an Edelbrock 1901 (I think that's the number), the down side quickly became the hard starting when hot. After putting a heat shield on the starter solenoid, no problems. The rich-running carb was being seen in gas-fouled spark plugs and popping in the exhaust. Oh, that and the acrid smell that burned your eyes. But the richer mixture is cooler and that is why the new carb caused the heat soak problem.
So be aware that leaning-out the carb by re-jetting it and changing the metering rods may cause a hot-start problem.
Member Nr. 2770
