Old 08-25-2007, 11:20 AM   #1
dan42
dan42's Avatar
Power steering for a '67
Yesterday there was a great thread on power steering for a non-power steering '67, and it was clear that you should indent the frame to fit the box in. I was wondering if anybody knew of a power steering box that you can buy after market that you don't have to do that to the frame - ? Where could you get it, and if there would be much modification to install it. Thanks in advance.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 08-25-2007, 01:29 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Power steering for a '67
I've mentioned this before in another threaed.
I didn't have to bend, cut or form anything when I converted my 68 GMC 250 and 69 Chevy 250 to power steering. I believe the p.s. for the Chevy I took off a 75 or 79 Impala. The GMC I believe came off a Dodge truck-don't remember for sure. Only thing I did with the GMC is put some washer to shim one end. But that was it...
Evidently, there are some that will work that don't require you to do any modifications but you will have to look around.
If I remember, I will take some pics of mine tomorrow and see if anyone can identify the differences.
68gmsee is offline   Reply With Quote
Old 08-25-2007, 01:35 PM   #3
redhead69
fugedaboutit
redhead69's Avatar
I always wondered if the 62-66 power steering conversion kits would work. 67 were offered with power steering just a different type (ram setup) and Ive seen them for sale by members in the 150.00 range.
Currently truckless
redhead69 is offline   Reply With Quote
Old 08-25-2007, 02:34 PM   #4
John Fabris
TOTY 2006
John Fabris's Avatar
68gmsee, keep in mind that the 67 frame is different then your 68 frame. 67 was a one year frame where the rail is flat where the gearbox mounts.... Your 68 frame will have a curve in that area....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-25-2007, 03:16 PM   #5
redhead69
fugedaboutit
redhead69's Avatar
Legend has it early 68s are like that too
Currently truckless
Old 08-25-2007, 04:54 PM   #6
Dennis` Pickup Parts in Pinellas Park,FL has a spacer for this. www.dennischevytruckparts.com
Old 08-25-2007, 05:18 PM   #7
bills68panel
thats true my 68 panel was flat i had to get out the wammy and get after it. it was'nt that big of a deal it took about 5 mi. if you can ad a little heat it really goes easy.
bills68panel is offline   Reply With Quote
Old 08-25-2007, 05:23 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
I saw the kit.... $60! It looks like it moves the box out about 1/2".... my concern has always been that the steering would eventuelly bind and wear out the box or steering column since it won't be in a nice straight line anymore. Although.... it may be such a small difference in angle it may not matter.... I'm an engineer, I'm anal about things like that
I guess you would also have to pull the pitman arm off of the box and move it over a couple notches so the steering will be the same from lock to lock???
I just got a complete freebie system off of a 72, so if I ever get my own garage, I'm going to dimple my frame.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 08-25-2007, 11:12 PM   #9
Ok Mr.Engineer,figure the approximate length of the shaft from the mounting point under the dash to the rearward mounting point at the box.Now,figure what angle we`re talkin`.Oh wait...I said approximate.you prolly can`t deal with that.J/K...Seriously,you could always go measure yours to satisfy your need for accuracy.I doubt it would ever present a problem.There`s always u-joints.I think the big hangup for most guys with heating and pounding the frame is that is already a weak spot in the frame and has been known to break at the box since there`s lateral torsional stress from the steering,a constant push/pull effect and heating takes temper from steel.
