Old 08-27-2007, 09:28 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Bending new tranmission lines.
Has anyone bent new transmission lines? I bought new lines to install. The old ones worked but the fittings were almost gone. I could not get a wrench on them. I had to use vicegrips to remove them. I was thinking of routing the hose above headers along the valve cover. The ceramic coated headers will keep the engine bay temps down. I do have the clips to hold the lines along the oil pan.
Any suggestions or pictures?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 08-28-2007, 12:46 AM   #2
shadetree
shadetree's Avatar
Re: Bending new tranmission lines.
I've bent fuel, trans & brake lines. For smoothe tight radii, pack tubing with sand, the sand keeps the tube from collapsing.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 08-28-2007, 02:26 AM   #3
gchemist
gchemist's Avatar
Thanks for the tip. I do have some sand to use. I'll post pictures of the fuel and transmission lines.
Old 08-28-2007, 11:45 AM   #4
us111
they also make cheap bending tools that work well,,but sand as they said works great..
us111 is offline   Reply With Quote
Old 08-28-2007, 11:10 PM   #5
shadetree
shadetree's Avatar
I should have stated in original reply that I use a good bending tool and sand. Without the sand in a tight radius, the walls collapse, no matter how good the bending tool is.
Old 08-28-2007, 11:22 PM   #6
pcmcobra
pcmcobra's Avatar
excellent tip....
thx
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 08-28-2007, 11:28 PM   #7
bigblock73
yeller
bigblock73's Avatar
Yes, sandblasting sand works great for bending lines, especially ones with a tight bend, or a bend near the end of a line that will not fit into a bender. Here are my carb lines, bent by hand (stuffed with sand).
G, here is what I did with my transmission lines...a little more expensive, but easy to do and they can be routed wherever you want.
http://www.73-87.com/7387garage/driv...anny_hoses.htm
bigblock73 is offline   Reply With Quote
Old 08-28-2007, 11:54 PM   #8
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I see your Chokeless?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 08-28-2007, 11:57 PM   #9
bigblock73
yeller
bigblock73's Avatar
Yeah, manual.
Old 08-29-2007, 09:37 PM   #10
gchemist
gchemist's Avatar
I installed the fuel line today. Today was the first time I used a bending tool. I did fill the line with sand. I had a hard time getting it out because of the bends. I flushed it out with air.
In time I'll probably give it another try to get the line closer to the engine. Having air all the way around may be better too. The line is really close to the heater hose connection. I'll have to bend the fuel line so it does not touch the heater hose.
Transmission lines, starter and radiator go in tomorrow!!
