08-28-2007, 07:14 PM | #1 |
removing stock balljoints
i'm fixin' to freshen up the front end, and I'm thinking ball joints are a priority. I've done the air chisel approach before and seems to butcher the a-arms a bit. drill bits don't seem to quite handle the job either..
anyone have a good trick for removing the rivets?
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. " |
08-28-2007, 07:24 PM | #2 |
Junior Member
Re: removing stock balljoints
your friend the 4" grinder. just be careful & grind the heads off...
frontstreetcycle on Instagram |
08-28-2007, 07:41 PM | #3 |
i like to use my 3" cutoff tool its quite a bit quicker and easier to get in with than a grinder
08-28-2007, 07:58 PM | #4 |
I agree with the grinder. Grind the heads down flat, then take a punch and hammer and drive the rivets out.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
08-28-2007, 09:11 PM | #5 |
thanks all, I wasn't looking forward to the chisel again!
08-28-2007, 09:26 PM | #6 |
grinding worked for me!
08-28-2007, 09:35 PM | #7 |
Crew Cut
that will work on the upper ball joints. do you know how to replace the lower ?
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
08-28-2007, 10:01 PM | #8 |
Next project: 1970 K10
Ball joint press, looks like a big C clamp.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-28-2007, 10:30 PM | #9 |
i was able to nock the lower ball joints out with a large socket and BFH. I then went to autozone and purcahsed there bal joint press and then pressed the lowers in with no pproblem! If you didn't know.... Autozone has a tool lending program... you essentially purchase the tool and then return it for a full refund with no questions asked!
08-28-2007, 11:19 PM | #10 |
Lower ball joints - remove lower a-arm and take to a shop. It is quick and easy with a hydraulic press and they can also press the new ones in at the same time. They can also let you know if the lower b-jt goes in to easy....this would indicate the hole for the ball joint is worn....found this on one of my '67's I worked on. Required a trip to the junk yard for a new lower a-arm.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, 2009 Acura MDX |
08-28-2007, 11:22 PM | #11 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
