08-29-2007, 03:01 AM | #1 |
Out of the carpool lane.
Sounds like Castrol is coming out with a new oil for our classics
http://www.castrol.com/castrol/gener...tentId=7032644
I hear it'll be out by October. Not sure I'll be using it- these old L6's will run without any oil at all, but might be just the ticket for many of you.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
08-29-2007, 03:16 AM | #2 | |
Re: Sounds like Castrol is coming out with a new oil for our classics
there has been threads about this issue. does this affect all flat tappet hydraulic lifter engines? i have a 1994 454. will my engine require this type of oil?
this had me concerned
08-29-2007, 03:47 AM | #3 | |
Wishin' I had more money!
That's a pretty thick oil! But reading at the bottom it says it's for pre-49 up till 73. Does that mean I can't run it in my 80? lol
combustion, this quote was taken directly from his link: Quote:
08-29-2007, 04:05 AM | #4 | ||
lol that's fine. its in my 71 custom. so its not gonna matter since i don't even have cats haha. I'm just concerned because i heard that its affecting flat tappet motors like i said. this had me freaked out. so does this mean that i can run regular motor oil in my gen 5 454?
08-29-2007, 05:27 AM | #5 |
Interesting development. I have been running Valvoline 20W-50 Synpower (full synth) in the V8 350 of my '71 Jimmy. I run straight Valvoline SAE 30 in my 292 L6 on the '68 C/10. It seems to like the straight oil. It gave a growl of appreciation after I changed back to 30 weight. I will probably go back to 20-W50 in the winter.
I have no aversion to Castrol. I have a couple cases of it on my shelf.
08-29-2007, 07:37 AM | #6 |
Most old engines should be cured well enough by now that it shouldn't make that much of a difference
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
08-29-2007, 08:45 AM | #7 |
You can run Shell Rotella T.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-29-2007, 03:12 PM | #8 | |
its all about the +6 inches
The only exception to that rule today, is royal purple, they never reduced the zink levels in there oils. That WAS true.. but the new diesel Shell Rotella 15/40 has NO zink in it. |
08-29-2007, 03:35 PM | #9 |
60-66 Nut
How about Delo 400?......I haven't looked at any lately. I know it used to be recomended for gas engines with flat tappet cams. In fact Crane cams rec omends using Shell RotellaT, Chevron Delo 400 or Mobile DELVAC oils......read it on their site not long ago.
08-29-2007, 03:46 PM | #10 | |
Crap, when did that start? Must have been real recent?
08-29-2007, 04:21 PM | #11 |
I was planning to switch to Royal Purple on my next oil change. Sounds like that might be a good move.
08-29-2007, 05:36 PM | #12 |
redneck, it is real recent. In all reality, what you find on the shelf is probably still the zink stuff, but they aren't making it anymore.
I don't know about the other diesel oils, however, I would assume they have gone minimal/or without. The oil companies didn't want to do this, the auto makers convinced the feds to require it. |
08-29-2007, 06:27 PM | #13 | |
I hate idiot lights!!! I know, you can't fix stupid Last edited by 71tahoe; 08-29-2007 at 06:30 PM. |
08-29-2007, 06:59 PM | #14 |
70rs/ss had something very similar happen to him as a teenager. He just kept going until he was home!
10-03-2007, 02:09 PM | #15 |
Anyone know if this is out yet? I need to change my oil real soon in the '67
I did too! I was 17 and driving back from Erie, PA on the interstate going about 70 (had the truck floored ). It had a 250 six and 3 speed. I checked the oil before I left and it was good. I got back (about 90 miles round trip later) and saw oil all move my tailgate? Apparently, it decided to blow out the vent tube thing on the side of the engine. No oil registered on the dipstick Put oil back in it and drove the dang thing about another 10K before I pulled a good running 6 out for a 350
10-03-2007, 11:14 PM | #16 |
"Trucks with Class"
This does seem to be a concern for flat tappet cams...they need the wear protection of zinc & phospherous...now gone in all oils.
That new Castrol should be the answer, but pretty spendy as most synthetics go...and so many of our old used engines use some oil $$$. All of our warehouses have been out of the old good oil for some time. You are looking for the old "SL" rated oils...not the new "SM". Check the back of the bottles for these symbols. GM's "OES" (engine oil supplement) is recommended for adding zinc, etc back into your oil. That could get a little expensive, too. Valvoline has a new "BLUE" oil for diesels that may show some promise...TBD. Chevys are notorious for wiping out cams & lifters, so this isn't going to help. If you are building a new engine, consider roller lifters. |
10-03-2007, 11:30 PM | #17 |
Valvoline "Racing" oils all seem to have the missing zinc.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
10-04-2007, 12:02 AM | #18 |
Well, Whoop-dee-do!
The new "CJ-4" diesel oils made for '07 diesel emissions w/ DPF systems are low- ash formulas. They are supposed to be cleaner burning oils with better lubrication properties. I can't find anything about their zinc content, but I would bet it is non- existent, since it wouldn't be needed. Most HD/ MD diesel engines that are worth acknowledging have been roller- cammed for decades. Also, CJ-4 oils are not recommended for older engines with non- synthetic gaskets & seals as it can cause leaks.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
10-04-2007, 06:27 AM | #19 |
blood type; Retumbo
the reason it stops at 73 is in 74 they came with converters. Zinc plugs up converters. (this is why the car makers lobbied for the zinc removal, so they could extend the warranties and not pay for it later) Castrol is doing the "lawyer induced dance" when they mention the pre-73 issue to avoid any legal issues. over a long time frame you will see a drop in converter efficiency and higher emissions. if you are like me and live in a no test state it will be fine. otherwise plan to replace the cat every 5 years or so.
10-04-2007, 07:10 AM | #20 |
Is anyone making a Zinc-only additive? So you could add it in along with your regular oil at oil changes. I saw on another thread [possibly in Engine & Drivetrain] about how GM EOS was discontinued or no longer available.
10-04-2007, 10:07 AM | #21 |
all that is is a 20w50 synthetic. amsoil makes the same thing. if you do a search for it on google you can find it and order it shipped to your door. but be prepared to pay 9.50 per qt. i run it in my bmw. awesome stuff.
10-04-2007, 04:38 PM | #22 |
Weekend Warrior
I've been running "Castrol" Tection Extra in my daily. I seem to have had good luck finding @ Wal Mart around CT. It actually says on the back of the bottle that it contains "ZincDi.......phospate" or whatever it is some long drawn out thing. I don't know how much is in there, but the fact that it actually says it on the bottle gives me some peace of mind.
In the hot rod (i.e. Built Motor) I broke it in with regular Castrol and added Crane's "Super Break-In Concentrate" and I put a bottle in after break-in as well. "Valvoline Racing" also says that it contains Zinc/ZDDP's on the back of the bottle - and you can get that @ AutoZone etc. http://www.valvoline.com/pages/produ...sp?product=50# http://www.valvoline.com/pages/produ...asp?product=94 http://www.valvoline.com/pages/produ...asp?product=95 I put the Valvoline Racing VR1 20/50 in the BBC hot rod motor this last time. Although now that I think about it - you probably want the one that says "Not Street Legal" as it probably has more ZINC and crap that the Gov't doesn't want in the air
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered Last edited by arkracing; 10-04-2007 at 04:39 PM. |
10-06-2007, 12:29 AM | #23 |
10-06-2007, 01:58 AM | #24 |
I broke in my cam on Valvoline Premium Blue 15W-40 and had good results. The rating was unclear because it said CI-4 plus in the circular logo, but then it listed CJ-4 under it with all the other applications.
Not sure what the deal is with zinc and CJ-4 oils but I don't think they completely wiped out the zinc. I was doing research awhile back and it seems that the CJ-4 oils still had decent zinc content. I do remember that Shell was going to continue selling CI-4 plus Rotella in 55 gallon drums. Chances are if you go to a truck stop or diesel shop, you might be able to find it. I checked Valvoline's website as well, and they offer CI-4 plus Premium Blue as "Premium Blue Classic" in 5 gallon buckets. |
10-06-2007, 03:07 AM | #25 |
The link below is to the company that originally bottled the Kendall oil (the sticky green stuff, notice company address)
If you call the company, they will get you in contact with the distributors in your area. The MSDS sheets for the oils I looked up show a content of "1% Zinc" Any questions PM me... My boss is a distributor, but it would be costly to ship (we are in South Dakota) http://www.amref.com/bp_product_pgs/BPengoils.htm
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
