Slugish
![]() Join Date: Jan 2005
iHAVE A 408 CI. SMALL BLOCK IN MY 84. ITS PROBABLY AROUND 375- 400 HP. BASED ON WHATS BEEN DONE TO IT. iHAVE HEDMAN HEADERS GOING TO 3 IN. COLLECTERS GOING INTO 1 PERFORMANCE (CATCO, i think) converter. then a single 3 in. pipe going to a single flowmaster .with 2 2 1/4 pipes out the back . question : would I gain anything by :
*1 removing the cat. *2 running a true dual system #3 or getting a flowmaster (if they make them) with dual inlets & dual outlets , no cat . would this not act as a x pipe of sorts . Iread some where that even the perf. cats are pretty restrictive . Any ideas appreciated ![]() |
Junior Member
Re: Performance Gain By Removing Cat.
flowmaster mufflers dont flow very much better than OEM. a strait through muffler like a bullet one or magnaflow moves air much better. when i deleted my cat on my camaro i felt a TINY difference, but when i did on my truck i felt nothing, probably because the truck is so much heavier and that small amount of power is not noticable. your setup with the 3" I pipe is like the one i have on my camaro, cept i have no cat. its LT headers, 3" collectors into 3" Y into a 3" I pipe, then single magnaflow with dual 2.5" outlets. ditching the cat and picking up a higher flowing muffler is probably the cheapest way you can do it, although nothing beats true duals for performance and sound.
![]() or you can do a cutout right before the cat and have no resistance when you want it
1979 K10 reg cab short bed 33x12.50s - GONE 1988 4x4 reg cab long bed 337k miles - GONE 1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE 1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE 1994 Z28 M6 1995 Z71 GT4 G80 ext cab short bed 215k GONE 1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE 2003 Avalanche Z71 GT4 G80 165k miles |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
You won't gain any if it is going through a performance cat. A 3" single is equivalent in flow to dual 2.5" You biggest gain would be from deficit from your bank account.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 08-31-2007 at 03:26 PM. |
