Old 07-26-2007, 05:10 PM   #1
slepysal
slepysal's Avatar
Non power brake master cyl
I have a ? about what master cylinder to use. I am going to go with non power brakes,and am wondering what master cylinder to use. Any help?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-26-2007, 05:57 PM   #2
mbgmike
Re: Non power brake master cyl
If you have drums all the way around you can just use a manual brake master cylinder. For safety you would use a two chamber equal size master. Most manual GM masters are kind of universal. They do not cost much.The single chamber ones are pretty useless and not very safe.
mbgmike is offline   Reply With Quote
Old 07-26-2007, 06:00 PM   #3
jchav62
1962 C-10
jchav62's Avatar
Order one for a 72 truck that has discs in front and drums and back, non-power.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-26-2007, 06:05 PM   #4
mbgmike
Yeah we sell those to. Would not really hurt. Mainly its the bore size. The Larger front reservoir really won't matter. Keep the bore size 1"
Old 07-26-2007, 06:15 PM   #5
slepysal
slepysal's Avatar
I should have mentioned Im installing spindles/discs. Thanks
Old 07-26-2007, 06:17 PM   #6
mbgmike
Yeah makes a difference
Old 07-26-2007, 08:51 PM   #7
rickf
rickf's Avatar
Does two-chambers mean you have to have two failures before you have no brakes?
rickf is offline   Reply With Quote
Old 07-27-2007, 01:25 AM   #8
allen57
kinda, it has a individual chamber for each set of brake, one for the front and another for the rear. thats y they have 2 lines going out of the mc. that way if one fails u still have the other
allen57 is offline   Reply With Quote
Old 07-27-2007, 11:22 AM   #9
PrerunnerRob
PrerunnerRob's Avatar
I talked to John (chiefrocka) before about this, and here is the master cylinder that he said would work. Cheap, for non power brakes, and it bolts right up supposedly!
http://www.partsamerica.com/productd...pe=230&PTSet=A
PrerunnerRob is offline   Reply With Quote
Old 07-29-2007, 05:45 AM   #10
63 & 64 Bowties
and a few others
you know if the push rod needed to be trimmed or modified?
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 07-29-2007, 08:52 AM   #11
fercho71
fercho71's Avatar
so mine its a single chamber, than for what i have read its much better to go for the double chamber?
its there other modification need it to install one of this?
1966 chevy c-20 truck " La Chata " under construccion
fercho71 is offline   Reply With Quote
Old 08-30-2007, 09:57 PM   #12
PrerunnerRob
Yep, you have to split the front and rear lines into 2 circuits.
Old 08-31-2007, 05:49 AM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey Sal...I have a master off of a 76-77 Full Size GM car....Cutless to be exact....front disc and rear drum.
I bought it new for the car years ago..took it off when the car blew up. Been sitting ever since.
You can have it if you think it will work.
Let me make sure I still have it on my shelf...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-31-2007, 11:12 AM   #14
slepysal
slepysal's Avatar
Thanks John I picked one off of a 72 pu. Hey I found the radio delete It's yours Monster Garage style...... freebie zilch nada zero.
Old 09-04-2007, 11:12 PM   #15
Dadsredwagon
Dadsredwagon's Avatar
any pics of the split of the brake lines? I need this upgrade....
Dadsredwagon is offline   Reply With Quote
Old 09-05-2007, 10:30 PM   #16
Tomsriv
Tomsriv's Avatar
Why no power brakes with disc brakes? It takes more effort to stop disc brakes because they are not self-energizing like drums.
Tomsriv is offline   Reply With Quote
Old 09-05-2007, 11:10 PM   #17
slepysal
slepysal's Avatar
Why? I have no room,I have a 6 cyl with a cliford manifold and the booster will hit it.
I guess non power brakes are better then no power drums.
