Old 09-01-2007, 01:43 PM   #1
Peter82
Everything is Custom
Peter82's Avatar
Question Tranys... What kind and Where to get one
Good day my fine men. i dont know what kind of a trany i have but i have a Chevy 350 and i need a better trany that is better on fuel. i also need new gears on the rear dif for better fuel use. SO... what is a good set up for a trany and the rear dif? My buddy said something aboout a turbo 40o cuz it has over drive... And last, where do i find all this stuff?
Peter82 is offline   Reply With Quote
Old 09-01-2007, 02:13 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Tranys... What kind and Where to get one
Turbo 400 does not have an overdrive. Your options are a th350 with 3.07 gears, this will put you about 2000 rpm at hiway speed. For overdrive you can put a 200-4R in with the same driveshaft. This lets you use a 3.42 or 3.73 rear end which gives you better take off and still run the same rpms on the hiway. Or if you want a 700-R4 you'll have to shorten your driveshaft but other than that it has the same advantages as the 200.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 09-01-2007, 02:58 PM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
The 700-R4 / 4L60 trans w/ 3.73 diff is a good & relatively inexpensive setup. Check w/ TCI for a decent tranny that has the constant pressure valve body...this greatly reduces the "finicky-ness" of the stock TV cable hookup.
You can also get a Gear Vendors overdrive unit that bolts on to your stock tranny and also provides an overdrive...these are a bit pricey, but bulletproof.
I am currently doing some research on the 5L50e trans out of a late 90's Caddilac STS. It's a five speed auto so it should have some great gear spacing, plus OD. The only question is does the Northstar V8 have a different bell housing profile then the standard SBC. I'll most likely need to have a custom drive-shaft fabricated and the linkage will be need to be figured out.
As far as diff gears are concerned....check with Yukon, Richmond, or any number of ring and pinion gear manufacturers. Unless you are setup and knowledgeable of how to assemble a differential, I'd definately leave this up to a professional.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 09-02-2007, 09:17 PM   #4
Peter82
Peter82's Avatar
thanks for the help guys... i am sure i am not the only one wondering about this. Dingfodgy when you find out about that trany will you let me know?
Old 09-25-2007, 08:42 PM   #5
Peter82
Peter82's Avatar
Any body eals have input for this Thread??? i am getting ready to put some money in this truck... also i am looking for a shortbed with out sidestep - for a 1971 c-10 and both doors. i dont want to spend a lot of money on this truck and all the things i want/need from LMC will cost me about $2,500.
any one got feed back on this idea?
Old 09-25-2007, 08:51 PM   #6
ChevyC102007
ChevyC102007's Avatar
I agree with the other two posts on this one. Either the 200 or the 700 will work great for over drive tranny's. If I remember correctly the 200 is based loosly on the TH350 3spd and the 700 is based off the 400. If ya like banging gears Id go with either a 5 spd or a 6spd manual. Just my .02
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 09-26-2007, 01:17 PM   #7
Dova
Dova's Avatar
what is the difference in the 200r4 and the 700r4 besides losesly being based off the 350 and 400?
Dova is offline   Reply With Quote
Old 09-26-2007, 01:39 PM   #8
Blue71LWB
Blue71LWB's Avatar
QUOTE=Dova;2375590]what is the difference in the 200r4 and the 700r4 besides losesly being based off the 350 and 400?[/QUOTE]
The 200 was the overdrive for the Caprice and other full size GM cars . The 700 was put in the trucks probably the van also, not sure though.
I think the most popular seems to be the 700R4 conversion. There are a couple of write ups about this in the Faq forum. http://67-72chevytrucks.com/vboard/s...ad.php?t=33266
Thanks,
Blue71LWB is offline   Reply With Quote
Old 09-26-2007, 02:32 PM   #9
Orange
Licensed to Thrill!
Orange's Avatar
700R4 from a reputable shop and a Bowtie Overdrive TV Made EZ kit.
You can't go wrong.
I LOVE my Godfather 700R from Maddog Transmissions.
But, I have now read some negative on them, and they are out of business I think. Goodfella's on eBay looks to be similar to what I got (their top of the line would be "The Boss").
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 09-26-2007, 02:41 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
First, we need to know what gears your truck has... and what your budget is.
If you have a 3.07 gear, and you go to a 3.73 and an overdrive tranny, then your RPMs will only chainge a little bit. Not enough to matter in all reality.
Now, if you do that, and you drop $3000... you'll be ticked off BIG TIME.
You can't go and try to improve on the unknown.
Old 09-26-2007, 04:25 PM   #11
70cst
70cst's Avatar
Ok...I was on the same page until the comment
was made. Explaination please? Maybe my brain is in a temporary freeze.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-26-2007, 05:44 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Peter,before you go spending money on body/trim parts try the vendors from the BB.They tend to have better pricing and great customer service.They also use what they sell so have tried to find the best quality parts available.There are links for them and for reveiws of their service.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-26-2007, 10:37 PM   #13
Peter82
Peter82's Avatar
OK so what is the BB? is there a web page or a phone number. i am new to all this classic truck stuff. i have been buying new cars and motorcycles for quite sometime now. Please help my dumb ass...
Old 09-26-2007, 11:41 PM   #14
heavy71chevy
heavy71chevy's Avatar
BB= bullitin board..theres a list of vendors here on the board who are also into 67-72s..they most likely have better service and better pricingthen lmc..so it be better for you in the long run if you check them out before you buy lmc...cause they can save you some $$$
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 09-27-2007, 01:17 PM   #15
Peter82
Peter82's Avatar
do they make a 5 speed or 6 speed automatic tranny for my 350? or is that the 200 and 700 trannys? i want to get rid of my 3 speed auto i got now.
Old 09-27-2007, 02:30 PM   #16
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
You can't go wrong.
An overdrive transmission WITH an overdrive conversion on it as well???
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-27-2007, 02:42 PM   #17
Scott68-93-97
Scott68-93-97's Avatar
Isnt the caddy FWD, Ive seen 4x4 guys run them instead of a tranny and case they run the driveshafts off the cv flange, so is the STS FWD IO thought they were??
If you have a long shaft th350 you can put in a 700r4 or 4l60e without much mods there under a half inch longer than the long shaft 350 so driveline usually can stay, the 200 is not that great of a tranny in my eyes Ive had em blow up but one of the built 200's from bowler or moster tranny would probably hold up
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 09-27-2007, 04:46 PM   #18
Orange
Licensed to Thrill!
Orange's Avatar
I am really surprised you haven't seen the TV Made EZ Bob, you've been on here for while.
Bowtie Overdrive = Company.
TV Made EZ = Kit.
http://www.tvmadeez.com/
That's the ONLY way to hook up a TV cable in my opinion.
Did it on mine, and it was a snap.
DLB
Old 09-27-2007, 05:00 PM   #19
glock35ipsc
I thought is was an overdrive kit like a Gear Vendors OD kit! OK, I feel stoooopid now.......
Bob
Old 09-27-2007, 07:39 PM   #20
Scott68-93-97
Stoooopid is repeating mistakes call yourself educated or enlightened
Old 09-27-2007, 10:04 PM   #21
Blue71LWB
Blue71LWB's Avatar
Here is my question.
I want to run the 2004R behind my 250 inline. I think the gear ratio will be better.
I have seen the custom crossmembers for the 700s but not one for the 200's are they the same ??
Also has anyone hooked a BTO TV EZEE to a 250 Monojet , is it possible ??
These are the only two questiopns keeping me from pulling the trigger
Thanks,
Zac
Old 09-27-2007, 10:25 PM   #22
Orange
Licensed to Thrill!
Orange's Avatar
Thanks,
Zac
#1 - A custom crossmember for the 700R4 or 200R4 for our trucks is unnecessary. All you have to do is move it back a few inches, and drill some new holes. That just don't warrant the money for a new one for me.
#2 - ANYTHING is possible with a little ingenuity. I don't know that they make a kit for your carb - but you could call them and ask what would be best. They may have a "universal" style kit.
DLB
Old 09-27-2007, 10:26 PM   #23
Longhorn Man
Zac, if you start your own thread, you'll get more traffic and responses.
I'll say there is no need for a custom cross member.
No idea on the carb deal... maybe call them?
Old 09-27-2007, 10:28 PM   #24
Longhorn Man
LOL! he beat me to it with the same friggen answers!
Actually, no need to drill holes for the 200 4R, place the cross member in the TH400 position, use the shaft from a TH350 truck, and you're there! Run the TV kit (I also strongly recomend the bto kit) and you'll be in like flyn
Old 09-28-2007, 10:26 AM   #25
Dova
Dova's Avatar
is the 700R4 good with 3.07 gears?
