Junior Member
Fuel filler idea?
I have looked at all the ideas on the board for fuel fillers for a fleet side. I like Hugger's tail light filler. The only problem is I am not going to have chrome around my tail light. So there would be a gap on the bottom of the light that I would not be able to cover up. I like the idea of the side marker light filler and the filler on top of bed stake pocket, but I don't like having to cut up a new bed side. With all that being said, I am tossing the idea around to fill from the bed floor. I found a gas filler on ebay that may would work. It is angled where I could have a straight shot into the filler neck of the blazer tank. Here is some pics of the filler from ebay and my bed floor. Tell me what you think.
1970 C-10 Fleet Side Gen IV 6.0 with 4L80E |
Re: Fuel filler idea?
i personaly don't like the fillers in the bed floor.i like to use my trucks,and i also think it's the easy way out, although i have seen som real nice craftsmenship on some. i do understand not wanting to cut a new bedside but if done well it is worth it. i did a sidemarker fill on my shortbox and love it. i finialy got to try it yesterday and it fill as fast as the pump will pump
common sense isn't so common anymore |
Project underway - finally.
Keep in mind that with the filler on the bed floor, you won't be able to fill with stuff in the bed - it could get annoying.
1972 GMC Pre-resto... awaiting allocated funding. |
I had the sidemarker fill on my truck and I loved it. Just extend the rear stake pocket enough to hide it and most people would never even know it was there.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I agree with the above posts. Also any dust, dirt, leaves & general crap laying in the bed floor might fall into the filler hole?
Great minds think alike,So do ours |
I have the filler in the side of the bed. Its from a 90 chevy s10 and the old filler neck has been teared drop to put a power antenna in. I hope this helps.
Next project: 1970 K10
I used one from Hagen Streetrods welded in to the bed side and also did a power frenched antenna where the old filler was.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
I have the aftermarket side tank on my truck with the ugly aluminum fuel door on the side of the bed. I was going to put the filler for that tank on the inside of the bed, basically directly on the other side of where it is now. After noticing the tank sits lower than the chassis, I will not be using it anymore, but I am going to be putting a rear fuel cell in the truck and am going to put the filler in the rear on the inside bedside.
i used the same style filler in my bed floor.
there are some pics in my build thead
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
Old Skool Club
![]() Join Date: Jun 2001
Fillers in the bed floor aren't my cup of tea, but I have seen some I like. If your bed floor is wood (I know it isn't), there is a vendor who makes a kit to enable a bed board to flip up to allow access to the filler. When the bed board is flipped back down, nothing shows. Bed is still usable but be sure you don't need to get any gas while it is being used.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: May 2007
who sells the wood floor filler you spoke of?
Junior Member
I am also going to experiment with a s-10 fuel door hinge to use on the tail light. This may eliminate the need to add extra clearance for the tail light to swing out. I just need to trim the door back where it will fit. The hinge itself is narrow enough to into the taillight opening.
![]() Join Date: Jul 2001
I went a different route for my under bed tank. Very little hassle and works quite well at the pump. Never have had any back flow issues and the bed floor is available any time.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
"1972 C5"
What I did...
#15 |
![]() Join Date: Feb 2001
In twelve years I have never had a problem with the filler in the corner of my bed floor......Here's another option. The gas nozzle will go through the gas cap. You do not have to remove it to fill tank.
The last pic is mine. |
#16 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#17 |
Junior Member
I believe you are right. The light opening is just too tight.
#18 |
gringoloco good to see a fellow coonass where about in shreveport?
Heavy Chevy |
#19 |
Life, Be In It.....
![]() Join Date: Oct 2003
I have a step side bed and this is what we came up with
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
#20 |
A guy with a truck
Broadmoor
