Old 09-03-2007, 03:37 PM   #1
truckn'
truckn''s Avatar
motor I.D.
my truck has an inline 6cylinder that actually runs pretty awsome, but I am gonna put a 283 in instead. I need to identify the motor. Is there anyway to determine the c.i.d. on the motor? please help thx in advance alot of u guys have already given me alot of info. thank god for this web site. It expands ones knowledge
truckn' is offline   Reply With Quote
Old 09-03-2007, 06:29 PM   #2
tjchevy1965
Re: motor I.D.
Yes there is a way to identify the motor. LMC truck catalog has a page in its book that helps you identify your truck's parts, options, and motor I will attach it below. This should help!!
http://lmctruck.com/icatalog/cbe/0008.asp
"Hope you brought your wood screws...Ima blow ur doors off!!"
tjchevy1965 is offline   Reply With Quote
Old 09-03-2007, 07:40 PM   #3
truckn'
truckn''s Avatar
Re: motor I.D.
unfortunately it was the right direction, but the info is still not clear. the id number on the plate behind the distributor F0504CAB and then under that is 21W265479. none of these numbers match anything I've seen. thx for trying to help thoughName:  DSCN3011.jpg
Old 09-03-2007, 07:49 PM   #4
19GMC63
19GMC63's Avatar
Re: motor I.D.
yeah, that casting number doesn't show up on any lists, but I did find on another forum that casting number and it ended up being a 250cid.
19GMC63 is offline   Reply With Quote
Old 09-03-2007, 10:05 PM   #5
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Re: motor I.D.
same one that was put in mine too truckn' I was going to use it until I found an 84 cab and chassis to swap my cab onto. Anybody need a 250? LOL Jerry
ClassicAutoResto is offline   Reply With Quote
Old 09-03-2007, 10:08 PM   #6
truckn'
truckn''s Avatar
Re: motor I.D.
thx alot guys. Is there anyway to find out what year the 250 motor was an option for chevy/gmc truck?
Old 09-03-2007, 10:16 PM   #7
ClassicAutoResto
Rust Buster
Re: motor I.D.
68-84 on my cast number which I believe is the same as yours, I may be mistaken. It's been awhile since I researched mine, found out....and...and then the depression set in Until I found the 84 He He He...sorry guys looong day!
