Old 09-04-2007, 07:08 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Early vs. late control arms
All thing being equal i.e.: spindles, springs, brakes, etc.- if I swap my early(71-72) control arms out for late(73-87) arms, will my alignment be affected?
I know the upper balljoints are a different diameter, but will still bolt in place. The shaft pivot points will obviously be the same, but are the balljoint distances from the shaft equal? Also, is the bottom of the spring pocket on the same plane; given the same spring will there be more/less drop with one or the other?
The obvious answer is: "Just go get it aligned". Just want to know if I can bypass this.
Thanks -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-04-2007, 07:55 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Early vs. late control arms
Here's a diagram expalining what I mean:
-Chris
Old 09-05-2007, 12:18 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
I snapped a few pics for ya on a comparison. Looks like the spring cups are a little different, but as far as my tape measure says the distances are the same (that's what I though, but I wanted to verify first). Be careful though... that tape measure has been known to be off by an inch every now and again!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 09-05-2007, 06:37 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks Nate, that's exactly what I was looking for. The difference in pockets is actualy why I'm swapping. The 73-up is much shallower/wider, allowing a shorter cup which means more drop and a few more PSI for the front at ride height.
I also seem to remember something about the cross-shaft locating stud being diferent between the early/late crossmembers. Anyone run into this?
-Chris
Old 09-05-2007, 08:36 AM   #5
jlaird
jlaird's Avatar
one difference that I notice is the angle of the shock mount. The later style would come in handy for me right now because I wanted to fab up an upper shock mount, but the shock would hit the upper control arm. So I might have to adjust the positioning of that lower shock mount to something like what I see in the picture of the later control arm. sorry, just rambling...
jlaird is offline   Reply With Quote
Old 09-05-2007, 11:40 AM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
On mine I have 85 A-arms & never got to see the 67 ones, cuz the PO had already changed them out for some later year
From what I have heard, the earlier A-arms are narrower than the later ones & it makes sense to me
The locating pins on mine do not line up !!! & if the A-arms were narrower I would have less clearance issues
Hope this helps mang
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 09-06-2007, 12:01 PM   #7
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
My 85 arms lined up fine with my 71 crossmember locating studs. As long as you don't ahve a sectioned crossmember you should be fine.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
