Old 09-05-2007, 12:46 AM   #1
sameyrasmea72
sameyrasmea72's Avatar
BB motor mount ?
I have a bb with 72 only mounts and stands,but the frontend cross member is off a 72 that came with a sb, and the stands when set on the frame and cross member, there is only 3 of the four holes in the frame and cross member. Can I just line up the other 3 and drill the 4th hole in the cross member...... Thanks Jason
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 09-05-2007, 12:56 PM   #2
Bob Moore
Re: BB motor mount ?
Show some pictures and you'll get a better answer.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 09-05-2007, 01:43 PM   #3
chevy72blu
chevy72blu's Avatar
I mounted a BBC in my 72 using 73-87 SBC towers and it was a similar situation. I drilled the fourth hole and put a bolt through it, but I considered solid welding it to the x-member.
It should work fine either way
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
