Old 09-11-2007, 02:27 PM   #1
cleszkie
cleszkie's Avatar
Backing Plates for Swing Away Tire Carrier
I know this has been discussed here many times before, and I did a search on this topic on this site. But the threads that came up no longer showed the attached pictures that I needed to see.
Anyways - I bought a swing away carrier that came without the backing plates. No problem. I just fabbed the upper and lower backing plates out of steel strap and welded on nuts. I also welded on a piece of rod to the upper backing plate to help position it behind the rear quarter panel (like I remember seing in pictures). But when I tried to position the upper backing plate, I found that the plate was too thick to fit between the inner and outer bed skins. It seems that there is a vertical support spar that is connectd to the inside of the inner skin that makes the area very tight. How in the world is a backing plate supposed to fit up in there? I removed all of the welded on nuts, and the plate (3/8" thick) still could not fit up there. I have the plate bent to perfectly match the inner surface of the outter mounting plate, so it isn't a shape issue. Can anyone offer me some advise on making the backing plate or better yet post up pictures of the upper backing plate? I really do not want to mount this thing with sheet metal screws!
BTW - my truck did not originally come with the carrier if that makes any difference.
Thanks in advance.
cleszkie is offline   Reply With Quote
Old 09-11-2007, 03:48 PM   #2
tdkosta
tdkosta's Avatar
Re: Backing Plates for Swing Away Tire Carrier
Good question, anyone have any answers?
tdkosta is offline   Reply With Quote
Old 09-11-2007, 04:07 PM   #3
70rs/ss
70rs/ss's Avatar
Should've got the inner plates? I know that doesn't help, but that is a HUGE part of getting one. I have one and it is for sale, when I pull it apart I can shoot some picts of the brackets, But I'd guess without them the tire carrier is worth a lot less.
70rs/ss is offline   Reply With Quote
Old 09-11-2007, 05:58 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
The inner plates are about 1/4" thick and have threads on the holes. The upper plate has a long rod welded to it so you can get the thing up in the bed side.
I used to have photos I took for another board member, but they don't appear to be on this computer. I loaned some inner brackets to Nubomb so he could have some fabbed up. He had estimates done and due to the compound bend in both brackets to match the shape of the body panel, the cost of having them fabricated was going to be astronomical. He ended up getting a set from another board member.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-11-2007, 08:19 PM   #5
stomper
Junior Member
stomper's Avatar
I made my own with steel flat bar. Don't recall the thickness but just tapped the holes and it worked fine. Guess it musta been 1/4". Didn't weld a bar on the top one. Pulled it up by two strings thru the holes in quarter panel on either end and then threaded rod in the center hole to line up with outer bracket.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 09-12-2007, 09:18 PM   #6
cleszkie
cleszkie's Avatar
Well I'm pretty sure that my Blazer does not have room up there for the backing plate. There is a vertical spar that is welded to the inner skin that leaves about a 1/16 of an inch of clearance between the inner and outer skins (I measured the clearance after I drilled the holes in the quarter panel). In order to work around this I had to cut the backing plate I made into three pieces, getting rid of the middle section that would have interfered with the spar. After doing this, I was able to fit the two backing plate pieces into position and thread in the three bolts. I can't explain why my truck has that spar in that location. All I know is that I have a 72 K5 Blazer that was not originally fitted with the tire carrier. I'm just glad I got the thing bolted on with backing plates. I wonder if anyone else has had this problem.
BTW - I located a few pictures of the upper backing plate that BobbyK took a while back. The piece I fabbed up was identical in thickness and shape. No way an original piece would have worked either.
Old 09-12-2007, 10:36 PM   #7
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's the upper backing plate.
The round bar is attached so you can fish it up through the side maker hole and hold onto it while getting a bolt into it.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-12-2007, 11:34 PM   #8
bouncytruck
SKINNY TIRES RULE!
Has the bed skin been replaced on your rig? Sounds like you may need to make a custom swing away like BobbyK did.
bouncytruck 1972 K5
Old 09-13-2007, 03:07 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
pic's
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
