09-12-2007, 07:56 PM | #1 |
64-66 CHEVY JUNKIE
How to transplant a 350tbi ?
Has anyone done a write up or can tell me how to transplant a 1992 350 tbi and 700-r4 into my truck. I have the complete donor truck running so i think i have everything i may need, any intel or pictures would really help me out, Thanks Chris...
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
09-12-2007, 10:10 PM | #2 |
64-66 CHEVY JUNKIE
Re: How to transplant a 350tbi ?
ttt
09-13-2007, 12:47 AM | #3 |
Here's a link to one.
http://www.persh.org/Pickup/TBI-1.htm
63 short fleet Patina build http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one. |
09-13-2007, 01:35 AM | #4 |
i thought the bolt holes for the TBI intake were different from the older carb intakes?
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
09-13-2007, 02:12 AM | #5 |
i was wondering about that too m i thought they only fit the vortec head and LT1 heads something to do with the angle the bolts go trough the manifold
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
09-13-2007, 06:39 PM | #6 |
64-66 CHEVY JUNKIE
Thanks poorboy for that link but what im doing is wanting to use the complete 1992 350 tbi enigine and transmission and get it all in my 66, Dont get me wrong i just dont know what to kept off the donor truck, I dont know anything about tbi trucks im basic carb. man. It just seem like since i have the whole truck it would be easy to do. what do yall think??????
09-13-2007, 08:49 PM | #7 |
I would keep the complete engine/trans harness and the computer.
09-13-2007, 09:14 PM | #8 |
It would take work, but would be pretty straight forward.
I think two major items would be the electric in-tank fuel pump (TBI requires ~12 - 14 psi and needs return lines and tank vent) and the trans cross-member/mount (may or may not be a problem). With the stock harness, it would probably run best (in terms of mpg, reliability and performance) if you kept all the emission controls and and sensors on the engine. If you don't want all the emissions stuff, I would ditch the stock harness and look up Howell EFI or similar and use your stock computer. http://www.howellefi.com/shop/customer/home.php In terms of swap-related information, I would be searching the internet for 4x4 sites- they typically swap to TBI. If you have specific questions about the TBI system, check out my old stomping grounds: http://www.thirdgen.org/techboard/tbi/ The guys over there are top notch and know what they are talking about- a very good group. I have a 91 Camaro RS with a 383 Fast Burn engine in it, retained TBI and all emissions equipment- no SES lights or anything. You can do a lot with TBI. Best- S-D |
09-13-2007, 11:33 PM | #9 |
You need the engine and all of the components, plus with engine harness and computer. Mount the computer under your dash somewhere.. You want the fuel lines from the carb down and if you can all the way back. You can get an inline fuel pump from summit for about $140 that Holley makes for this swap. I have one for my truck.. I was going to put in a 350 TBI but I got a big block instead with the TBI unit.. I think the pump you want is this one http://store.summitracing.com/partde...5&autoview=sku I will look and see which one I have to double check..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-15-2007, 12:34 AM | #10 |
60-66 Nut
I would suggest going with an aftermarket harness. You could use the stock one, but that would require lots of time going through the harness with a wiring diagram and figuring how and where to hook up everything. There will be quite a bit involved with that swap, but well worth it IMO. To go over everything involved would be a bit lengthy....have you posted this in the 'engine' forum here? there are several knowledgable guys that frequent that forum.Another thing you could do for help is get an EFI swap book/guide. Most of them deal with TPI, but the basic FI system is the same. That would help you understand what all is involved with the swap. There's also lots to be found on the www, thirdgen is an excellent one as mentioned before. Here's a couple more where you might find info and help
http://www.fullsizechevy.com/forums http://www.pacificp.com/forum
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-15-2007 at 12:47 AM. |
09-15-2007, 10:16 AM | #11 |
I did two of those a few years ago. One I used a painless tbi harness(easy) the other, I spent hours with a service manual, removing unneeded wires and making other changes. As far as the fuel system, I simply used an inline fuel pump from holley, then made a return line to the tank. Otherwise the engine bolts in, the trans crossmember may need to be farther back though.
09-15-2007, 06:45 PM | #12 |
64-66 CHEVY JUNKIE
Thanks for the info guys,
09-17-2007, 11:02 PM | #13 |
64-66 CHEVY JUNKIE
I done a little more reading around and learned that the trans is a 4L60 non compu. my plans have change a little well alot, im going to use a carb and a lock-up kitt for the trans. and keep the tbi,harness and brain in case i want to go FI at a later day.
09-20-2007, 12:47 AM | #14 |
60-66 Nut
A word of advise....make sure the TV cable is hooked up and adjusted properly, otherwise you may fry that trans. IIRC it should be the same procedure as a 700R4 (same trans)
