09-13-2007, 12:54 PM | #1 |
Little help with a "hot starter"
I've noticed that my starter will quit on me after a long drive to the lake, hauling my boat in 100+ temperatures. It'll quit working for a few minutes, then it will turn. That's so far. Since this tends to happen on a boat launch ramp, you can understand my concern! I gather from reading some past postings that it's absorbing too much heat from the headers.
My questions:
Thanks! (PS- I will check to be sure the wiring is in good shape!)
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 09-13-2007 at 12:58 PM. Reason: add a ps |
09-13-2007, 12:58 PM | #2 |
Re: Little help with a "hot starter"
yes, it is causing permanent damage, ive gone through two with my headers, and they would slowly become weaker over time, and then go up in smoke...
if it hasnt become weaker yet, hurry up and get that starter blanket or heat shield before it does... |
09-13-2007, 01:04 PM | #3 |
Between Trucks...
A remote starter solenoid is supposed to help as well...
Beat it to fit, Paint it to match... |
09-13-2007, 01:08 PM | #4 |
I have the same problem with my truck but I still have the original manifolds and the down pipe is right against the starter (about a quarter of an inch) I cant put a conventional heat shield on due to the lack of space3 but Im going to get a heat blanket for it ASAP since its starting to click occasionally when I try to start the truck after its ran for abit.
If it aint one thing its another. Oh BTW I noticed when I changed the starter what looked like a conventional pad for a later model starter and NAPA does list such a starter for my truck, would this be an option to stop this since those starters are abit shorter?
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." [Cherokee saying] 2001 Dodge Ram Sport 1500 4x4. (old ride) 1987 GMC V1500 Sierra Classic ("new" ride) |
09-13-2007, 01:19 PM | #5 |
My truck had the same problem. I just finally put a new starter in a couple weeks ago. I also bought a solenoid heat shield and remote starter solenoid. I haven't had time to install either yet....
Also, the starter on my truck was physically small, that may have been some of the problem too? The solenoid and nose cones were the same, but the actual starter was about 30% smaller than the new one I bought. I just bought a replacement starter for a mid 70's truck and it was much bigger. My truck is a mutt, so it probably had some small car starter or something on it? So far, no "slow starts" even after an hour of driving.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 09-13-2007 at 01:19 PM. |
09-13-2007, 01:31 PM | #6 |
Not to hijack, but has anyone installed a F@%d remote solenoid?
'69 Fleet It ain't yours, if you didn't build it! |
09-13-2007, 01:36 PM | #7 |
Between Trucks...
I had one on my '72 LWB. I got the wiring diagram from the Summit kit online, and got the solenoid and wiring from a local parts place. Worked great. I need to put one on the '69 now...
Beat it to fit, Paint it to match... Last edited by Sinister; 09-13-2007 at 01:36 PM. |
09-13-2007, 01:42 PM | #8 |
Old Skool Club
I have read many posts about this same topic, but when it happened to mine several years ago, I had a heat shield installed. Didn't know how well it would work, but six years later there are no issues. I have headers and am still running the same starter almost 8 years after buying my truck. I didn't have a problem until I replaced my rich-running Edelbrock 1406, with a new Edelbrock 1901 Q-Jet, which ran much leaner causing the hotter-running engine and the heat soak which made starting difficult.
I'd put the heat shield on it, first. I'd let the results of that dictate my next step.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-13-2007, 01:50 PM | #9 |
I also did the Ford remote solenoid. It didn't help, but I think the starter was too far gone. With a new starter there have been know problems except when the flexplate stops at the spot where a tooth is missing.
09-13-2007, 01:55 PM | #10 |
ha, my old truck had some worn teeth, but it didnt have a dust cover, so i would just climb under and turn the flexplate a bit : )
09-13-2007, 02:04 PM | #11 |
I would go with the blanket and have thought about using header wrap either on the headers in that area or around the started. That stuff is awesome as far as stopping heat.
09-13-2007, 04:05 PM | #12 |
Probably the best thing for your situation is to get one of the later model delco permanent magnet starters. They are much smaller(more clearance between header), much much lighter(easier to install) and with the perm magnet the heat does not affect it anywhere near as much as the coil magnet. Plus its a direct bolt in.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-13-2007, 04:26 PM | #13 | |
Between Trucks...
09-13-2007, 04:39 PM | #14 |
Amen!
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
09-13-2007, 05:57 PM | #15 |
had the same problem, with my truck, jeep cherokee and a ford. intermittent starting was always a weak bendix spring. (including the ping/rattle caused by movement of the shaft allowing the gear to hit the flywheel) all cases were fixed by replacing the starter. With my Sierra, the HO motor and headers, I put a high torque starter in, it is half the size of a stock one. thus will not get as hot. going on 2 1/2 years now.
09-13-2007, 07:14 PM | #16 |
you could just try using exhaust heat wrap, it doesn't look the best but you could wrap the header in it and i won't get so hot and should save the starter.
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block |
09-13-2007, 07:15 PM | #17 |
it works pretty good to cause a friend used it on his motorcycle and it helped a lot
09-13-2007, 08:13 PM | #18 |
I got mine here about 3 yrs ago:
http://superpageshosting.com/4alters...n&catuid=11378
