Old 09-15-2007, 02:51 PM   #1
jott_06
Camaro Club
jott_06's Avatar
painting interior parts???
Ok my GMC has blue interior and to me it doesnt fit with how i'm doing the truck so i want to switch it to either black or grey. My question is my dash pad is in perfect shape so would it make since for me to just get a can of that duplicolor interior paint and just paint it. If so has anyone used this paint on a dash pad and how well did it work. i've only used it on hard plastic and it held up very well. Thanks for any info and suggestions
jott_06 is offline   Reply With Quote
Old 09-15-2007, 03:03 PM   #2
70cstjr
70cstjr's Avatar
Re: painting interior parts???
ive always found that krylon fusion spray paint works the best on rubber/plasic parts without flaking
here is what there site says
Recommended Surfaces:
Ceramic/Plaster
Glass
Hard Vinyl
Metal
Paper
Papier Mache
Plastic
Wicker
Wood
70cstjr is offline   Reply With Quote
Old 09-15-2007, 05:10 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I can't remember what the brand is, but I did my dash pad back in 2000, and other than a couple small chops (from packing the cab FULL of crap) it still looks great. I did black, over the med blue.
The headliner still looks perfect, but the door panles live a harder life and don't look too good at all.
Old 09-15-2007, 11:29 PM   #4
jorgensensc
jorgensensc's Avatar
I just did the dash pad on my truck. I used the matte black and it turned out great. However when I painted the vinyl door panels gloss red they turned out very splotchy. I will just have to reupholster those in red vinyl. I think the gloss colors are harder t o use and not get them splotchy. I used the vinyl dye in a can.
SHawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-16-2007, 01:15 AM   #5
72armyswbtruck
72armyswbtruck's Avatar
Just make sure that you do a really good job prepping the surface, ie using a good degreaser on the surface before painting it.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-16-2007, 08:57 AM   #6
jott_06
Camaro Club
jott_06's Avatar
When i painted the hard plastic with before i used rubbing alcohol and wiped everything down. it worked really good for removing all the old armoral(sp).
